Spreadsheet w/weights Focus
reedplayer
by reedplayer
Only Spreadsheet w/ weights of a Focus Izalco max
Spreadsheet with weights (in grams):
Frameset (size 52)
Frame 712 gr incl. cable guides,bolts, hanger front/rear
Fork 285 gr cut
Headset 80 gr
seatpost clamp carbonschmiede 5 gr
Bottom Bracket Bor PF30 73 gr
Total: 1155 gr
Seatpost ritchey flexlogic 27,2 350mm 180 gr
Seat Fizik Arione 135 gr
Stem FSA OS CSI 99 132 gr, Pro PLT 100 mm 10° 118 gr.
Bar FSA K-Force 40 cm 208 gr
Bartape Fizik 52 gr
bottle cages and hardware Bontrager 25 gr
Brakes Sram Red 10s 253 gr
Front derailleur New Sram Red 10s 69 gr
Rear derailleur New Sram Red 10s 145 gr
Crankset Rotor 3d+ P2max S-type incl. Praxis Work Chainrings 50/34 755 gr
Chain Dura Ace 260 gr
Shifters New Sram Red 293gr incl inner cables
Cassette Dura Ace 11/28 172 gr
Wheels: -Zipp 202 2013 tub. 1090 gr
-Mavic Rsys 2011 cl 1414 gr
Tires Schwalbe One HT 23 mm 266/264 gr
Veloflex Master cl 190/195 gr
Pedals Look Keo Carbon Ti 187 gr
Polar/garmin/computer mounts Garmin Edge 500
Tape/glue Tufo 25 gr
hermichut
by hermichut
Hello reedplayer,
I have just purchased a izalco max frame and fork which didn't come with an headset. Would you let me know which one you used?.
Thanks in advance!,
Hermichut.
reedplayer
by reedplayer
Hello Hermichut,
mine originally had an "acros-the-clamp" headset, i was not satisfied with. so i only kept the acros-bearings and replaced the remaining parts with a carbon-headset-cover from ebay, a top cap and an extralite ultrastar expander, to create a classical headset system.
looks like that:
afaik the current max-generation is equipped with a fsa orbit headset.
regards,
Squashednuts
by Squashednuts
hermichut wrote:Hello reedplayer,
Thanks in advance!,
Hermichut.
Hey, there was a recall for Acros headsets "The recall involves the 2014-15 model year Focus Izalco Max bikes with Acros-brand upper headsets. The headsets are black with the word "Acros" printed in white on the upper headset."
A cheapish headset is FSA Orbit C-33 ACB but there are several others that will fit
Crane-creek have a site that may be useful.
https://www.canecreek.com/headset-fit-finder
Good luck.
I really like the Izalco Max it has the potential to be a real WW
hermichut
by hermichut
Thanks a lot for the info guys!!..
I'm looking forward to building my izalco max up :-) !!!
Hermichut
