Designing and Building my own Carbon Fibre frame
euph
by euph
Thanks Clannagh
I was inspired by your Y Foil and used your write up on making the mould for the derailleur hanger as a basis for my process. So, thankyou!
Clannagh
by Clannagh
Cool, Im loving your 3D printer work looks amazing, I need a 3D printer!
Third and final year no pressure then! if you think I can help in any way just ask.
Good luck :thumbup:
Clannagh
by Clannagh
Just having a look at you wing mould, have you heard of Low melt thermoplastic moulding granules? you should be able to pick them up on eBay. Ideal for making fast prototype moulds. You add the granules to hot water they then form a malleable blob of plastic, form this around one half of your piece to be moulded, let it cool then form the other half. both sides can be cracked open once cooled, epoxy doesn't stick to it either so does away with all the mess of release agent etc. Speeds up the prototype/testing process no end and its reusable, drop you moulds back in hot water and they become malleable again ready to make a new mould. I guess you will have to try a bit on your 3D moulds first as it is probably made up of the same plastic but with a higher melt point so could stick to each other!
euph
by euph
That's not a bad idea. I looked at a few different options including some epoxy compatible moulding putty that you add hardener to then work it by hand and form around your part. I have heard of that type of thermoplastic but it never occurred to me that I could use it for moulds. I will continue with the fibreglass mould for the moment as I have all the supplies for it. However I will pick up some thermoplastic stuff and see if I have any success.
Thanks
alistaird
by alistaird
Interesting thread and good luck. Definitely subscribing to this one.
A
euph
by euph
Updates!
I had success with the fibreglass mould for the helicopter propeller so I have made a mould of the headtube.
I made an aluminium mandrel which can be disassembled and removed from the final part. The mandrel is the exact diameter of the final holes but a tad undersized. So this should provide a good inner diameter for the tubes and bearings.
I layed the carbon fibre up today and can already see some issues in the tighter corners but I will have to wait until it is out of the mould to see how it turns out. Experimentation and failure is the only way to learn!
I have spoken to clannagh and he has shown me a way to make inflatable bags for the inside of the mould which I will try after this attempt with the mandrels as I feel this will give guaranteed compression to all sections of the mould. This method will sacrifice the guaranteed hole sizes however if built oversize these can be machined out to spec.
Sorry for the picture dump. I still haven't figured out how to put pictures in the middle of text in Tapatalk.
euph
by euph
I made a headtube lug. It is definitely not good enough to be a final part but it has been reasonably successful for a first try.
I used slow hardener which means I have a longer pot life but the cure time is at least 30 hours which may have caused a few problems. The main problem is that the aluminium mandrel is quite heavy and has no indexing points which caused it to sink to one side. This has caused one side of the part to have a thinner wall than the other. Some of the tighter corners have got some voids as well. The part is strong though.
I will put some pictures up but please don't judge too hard! I will make a internal bladder for my next attempt which should work a lot better.
euph
by euph
Hey guys. Sorry for the lack of updates. I have been working on making samples for testing with the Instron Machine at uni. I am going to compare the compressive and tensile strength of multiple layups, the difference between post curing a part and not and also compare my results to the values stated on the datasheets given with the resin and fibre that I am using.
While I have been setting up for this I have refined my current process with the mandrels and experimented with some new processes involving air bladders. Thanks to Clannagh for giving me some pointers on how to make the air bladders.
I have made a few headtube lugs now as my main test part. Each one has been better than the last. My primary issue now is getting the inner diameter perfect as the tubes have to bond into them and bearings have to pressed in. We all know what a bottom bracket shell with poor tolerances causes so I am paying particular attention to getting these areas perfect.
I have also made a few chainstays. This is the only tube I am making on the whole bike and for my final report I will include some testing data on the deflection of the tube under different loads. The chainstays have come out very successfully and are very strong.
All of this is completely new to me so each attempt is a chance to learn and improve. Thanks for reading.
rekhyt
by rekhyt
Would be cool to see some more pics. Sure, things might not look as refined as those from builders with more experience, but at least i think it's more interesting to see the outcome of a DIY approach.
euph
by euph
I finished up my final headtube today. Finish is still a tad rough but I gave it a quick wetsand just to polish it up. Headset cups are ready to be pressed in but will wait until final assembly. Now to get the other two lugs to this level! ImageImageImageImage
chris47
by chris47
Cool! so very cool! and thanks for sharing :)
beanbiken
by beanbiken
chris47 wrote:
Fri Jan 26, 2018 7:27 am
Ditto, very interested to see how this pans out. Please keep the updates coming
BB
Ahhh, coffee & carbon
michel2
Location: somewere floating between here and the other side
by michel2
impressive work your doing !I build out of steel but would like to have ago with carbon (-:
why do you go with lugs over tube to tube ?
thanks, mick
euph
by euph
michel2
I have berated myself constantly for not going tube to tube the deeper I have got into this project as it probably would have been easier. I don't know this, however lugged has definitely proven difficult.
I went lugged because I was inspired by the early carbon fibre frames in the 90s which where just a step away from lugged steel and the beginning of exploring carbon fibre as a new material to make frames from. So I figured it would be a good a reasonable place to start, as that's where big manufacturers begun!
Hope that answers your question. Although I am struggling to justify it to myself. Weight, complexity and design limitations are many of the flaws with this method. Not to get ahead of myself but in time I will try a tube to tube frame with more focus on weight.
Thanks
prendrefeu
by prendrefeu
This is so exciting!
