Festka Scalatore
That’s a really love build, well done. Crazy light too
Specialized S-Works Venge Disc | 7.8kg
Rose Backroad | 9kg (Deceased R.I.P.)
Canyon Ultimate CF SL | 7.7kg
https://www.findyourroad.co.uk/
Instagram: @miles_bc
Shaved a bit more weight off with a few replacements:
1. Crankset - THM + Praxis
2. Chain - PYC 11s hollow pin
3. ISP Topper - KCNC zero offset
Gained some grams on the tires with Ritchey race slicks but they're more durable
Would appreciated any recommendations on the ff:
- Current handlebars are unbranded (185g), how about Darimo, AX, Schmolke, Mcfk?
- Thw Ciamillos Micro GSL are light, but are there better performing ones?
2021 Giant TCR Advanced SL0 Disc 6.8kg
2019 Specialized Allez Sprint Disc 7.9kg
2017 Festka Scalatore 5.375kg
Original account [shotgun]: memberlist.php?mode=viewprofile&u=10594
If they're correctly set up I'd say Ciamillos are already a pretty good combination of braking performance and weight. Maybe you could try THM fibulas though?
Beautiful bike
Beautiful bike
Absolutley love this. By any chance, do you remember where you sourced the unbranded bar, and has it held up well?
For the bars, I highly recommend the haero H.145. My size 42 bars are 156g actual weight, stiff, and have a 115 kg weight limit if I recall correctly, higher than the typical 100kg.shotgun1 wrote: ↑Fri Oct 09, 2020 5:03 amShaved a bit more weight off with a few replacements:
Actually I am replacing the bars with Pro Vibes to get an aero effect. Drop a message if you're interested in buying, I give weight weenie discounts.
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
It was sourced through FarmLim, a fellow WW from HK. So far it's held up well, I've used it over 4 yearsforegroundmusic wrote: ↑Fri Oct 09, 2020 12:12 pmAbsolutley love this. By any chance, do you remember where you sourced the unbranded bar, and has it held up well?
Oh lemme check them out, thanks. Also sent a message to your registered emial.Stendhal wrote: ↑Sat Oct 10, 2020 8:14 am
Lemme take a crack at them again, I'll change the pads and see if I can set things up properly. Yeah Fibulas are probably at the top of my list.
Thanks!
If your pads are worn out that might be why they aren't performing well. To take full advantage of the cam's leverage, you need to use spacers behind the brake pad holders to get the pads close to the rim rather than using the barrel adjuster*. Unfortunately the pads have to be quite close to the rim for the brakes to work properly so you get quite a short lever-throw, which not everyone likes. Hope that helps
* otherwise by the time the pads reach the rim, the brake will have already gone past its ideal range of motion.
I found the EE brakes set up this way work much better as well.themidge wrote: ↑Mon Oct 12, 2020 3:46 pmIf your pads are worn out that might be why they aren't performing well. To take full advantage of the cam's leverage, you need to use spacers behind the brake pad holders to get the pads close to the rim rather than using the barrel adjuster*. Unfortunately the pads have to be quite close to the rim for the brakes to work properly so you get quite a short lever-throw, which not everyone likes. Hope that helps
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
Hey Shotgun1,
I would like to recommend the Fibula brakes for your build.
I've heard some trash talked about them, but I've never had any issues after using them for several years (except breaking a spring , 100% my fault)
If you can pick a used 1st gen set for a good price and in good condition, you'll be 'sweet as bro'
Bit the bullet a few months back, a generous WW member [you know who you are, cheers!] was generous enough to sell me his Fibula set. I'll install them this weekend, and make a few more tweaks. I'm gunning for a 5.4kg total weight. I'll share some photos once done and if the weather clears up.Osoi3900 wrote: ↑Mon Oct 19, 2020 10:37 amHey Shotgun1,
