BMC Teammachine SLR01 (2018) 5.94kg
Moderators: MrCurrieinahurry, Moderator Team
ryzy
by ryzy
Hello. I’m planning to swap my old BMC frame to the 2018 frame. Any issues fitting the DA 9000 groupset to the 2018 frame? Any problem on the RD? Can I still use the old DA 9000 brake caliper?
bilwit
by bilwit
ryzy wrote:
Sun Dec 31, 2017 12:35 pm
Only problem I had was adjusting the calipers so that the break shoes wouldn't rub against the fork/frame to allow for more clearance for wider rims (25mm across). Took a lot of tweaking to get it right but it worked out in the end. Maybe I was just being a noob having no experience with DM brakes before :P
Chans1ee
by Chans1ee
That slr01 has perfect combination of color. I really like it.
I think new slr01 is one of the most advanced bike, also it has unique and beautiful design.
How about Osymetric chainrings? dont you have any shifting problems?
bilwit
by bilwit
Chans1ee wrote:
Sun Jan 07, 2018 7:39 pm
No shifting issues, I think they solved that problem pretty early on when they added guiding rails to them (they didn't have them in the first iteration). The huge drop in height throughout the pedal stroke makes it so that the chain can sometimes rub the bottom of the front derailleur cage when you're in the little ring if you aren't careful with where you're at on the cassette though. They're also 50 or so grams heavier than normal DA rings. Another thing is that it's pretty weird to use them after being on round rings for a while, feels like you're pedaling in squares at first.
quadzilla
by quadzilla
How do you like the FLO 45’s on the Team machine?
bilwit
by bilwit
quadzilla wrote:
Sun Jan 07, 2018 10:05 pm
tbh haven't been on them much at all. I used my chinese clinchers on them the few times I took it on the commute (wider & with tire liner) so can't comment on the FLOs. Been in the pits of pacific northwest fall/winter rain & cold season so the BMC has hardly seen any riding :x . Rightly so, I should say--the Altamont Ceramic Lites have taken a huge toll apparently with the ceramic coating completely gone by now and it's only been ~3 months. If I end up keeping the same commute next fall/winter I might be on a disc bike instead..
bilwit
by bilwit
After 1700kms on this thing I finally got around to taking a decent picture of it. Updated my phone to an S9 and which finally gives me access to a non-potato camera (though from how the pics came out it looks like I need to turn off HDR). Here's a pic with my commute wheels (40mm chinese carbon clinchers with Mr Tuffy tire liner.. I know, I know, but the stuff just works for me around here).
Few tweaks I made:
  • Kalloy UNO -17D 110mm
  • Absoluteblack chainring bolt covers
  • EE brakeshoes (completely solved the clearance issues with the front wheel)
Also retired the steel bike, parted it out and replaced it with a new dedicated wet/weather bike:
Didn't really intend to double up on BMC bikes but it just sort of ended up that way, the RM02 ticks all the boxes for the perfect weather bike :noidea:
The shop that sold me the Teammachine frameset-only back in October told me to go away when I asked to do the same for the Roadmachine, so I ended up asking the other BMC dealer around here which also declined BUT was willing to work with me when I asked if we could treat it as a custom build. They offered a 50% return on all the parts I wanted to swap out (which was virtually everything). I couldn't be bothered with reselling the stuff so I took them up on it, had them order and install a new set of Fizik Chameleon bars, DA9120 shifters & 9100 rotors/calipers, then took it home and assembled it with the DA9000 drivetrain and saddle from the steel bike. Wheels are light-bicycle CX36 (21mm internal, 28mm external) with Conti GPS4KS2 25mm tire on them (with tire liner inside). Also replaced the DT Swiss QR axles with ones from Robert Axle Project which ended up only shaving a tiny bit of weight (~20gs).
Weight as pictured with the head unit is 8.1kgs at size 54. With the low headset cone, the drop is actually lower than the Teammachine if I used the same -17D 110mm stem so I had to put on a -7D one to get it to just about the same as the Teammachine :shock:
Now I just need to get into time trialing and save up for a TimeMachine to complete the set :lol:
AZR3
by AZR3
Two bad ass looking BMCs :thumbup:
iamraymond
by iamraymond
Nice bikes! I measured the SLR01 and RM01 (with a tall cone) and found that there wasn’t actually a big difference in Stack. SLR01 was 555mm and RM01 was 560mm for a size 51 frame. I think BMC measures the SLR01 stack to the top of the headset and the RM01 stack to the top of the cone so it doesn’t account for the small cap on the SLR01.
I’d imagine if you measured the actual stack on the roadmachine with the low cone, it’d be surprising low.
bilwit
by bilwit
Did some weight juggling to get more aero. Not the most flattering pic but haven't taken this one outside much due to the weather:
  • DA9070 (got the FD, RD, STIs for $560 total as unused/parted out items on eBay)
  • ENVE SES Aero bars with Lizardskins taped up all the way to the stem + Raceware Wahoo bar mount mount
  • Berk Padded Lupina with oval rails (round rails snapped on me while on the trainer)
  • Light Bicycle R55 (front) + R65 (rear) with Industry Nine hubs & Vittoria Corsa G+s
  • Extralite HyperStem -12D 120mm
  • C-bear 4130 BB
  • Rotor 3D+ with Power2Max NG Eco & Rotor NoQ 53/36 rings
Before the changes it was around 6.6kg after I ditched Osymetric and went back with the DA9000 rings. Now it's 6.975kg as pictured with the Wahoo and 1x bottle cage. The Corsa's are a weight penalty compared to Conti GP4000s and I kept the tubeless tape the rims came installed with and used butyl tubes when I got them so I should be able to shed ~100g when I put veloplugs & latex tubes on.
The biggest weight penalties were the Rotor+P2M which was around ~200g heavier than the DA9000+Stages, followed by the ENVE Aero bars weighing ~40g or so heavier than the Fizik Cyrano 00 bars but functionally I'm pleased with it. Having the flat aero bars wrapped up is such a nice thing to have when you're just cruising on the flat (or on the trainer) while resting your forearms on it with the pseudo-aero-cancellara position. EE brakes would put me back in the semi-WW gang but atm I don't feel like trading the raw stopping power for extra modulation.
Also did the Di2+Enve Aero bar+Berk+HyperStem upgrade to the Roadmachine as well just in time for mucky weather season, should be able to get a proper pic for that one soon.
ultyguy
by ultyguy
Nice rides! What’s your saddle height and drop to the bars? I’m interested in BMC but I’m really stuck in the middle of a 54 or 56...
iamraymond
by iamraymond
Looks great with all the changes, especially the move to Di2. Did you get the seat post clamp sorted out?
plpete
by plpete
That's a very smart build - mechanically and aesthetically. I still love my 2012-13 SLR01 but seeing yours I kind of want to sand it down to bare carbon, mask out the BMC logo and paint it white.
Btw, dig the 53/36 ring combo!
bilwit
by bilwit
ultyguy wrote:
Fri Nov 16, 2018 8:59 am
54cm saddle-to-bb, 57cm from tip of saddle to center of the bars.. whatever drop that makes out to be :x
iamraymond wrote:
Fri Nov 16, 2018 1:34 pm
Not really.. pretty sure it will fall off on a ride at some point. Not sure what I can do about it. Maybe if/when I get a replacement the mold is better fitted..
:noidea:
theDmitry
by theDmitry
nice bike! great job
I would like to see from other angles to, I'm wondering how handlebars looks from above.
