Cervelo S3 eTap - not WW, but exhaustively weighed
964Cup
by 964Cup
Came out at 7.1kg. Component list with weights:
Code: Select all
g     Item
1102  S3 frameset, hanger, bottle bolts, grommets and stops
391   S3 fork, uncut
-30   Less: steerer removed
70    FSA for Cervelo headset, cap & bolt
2     Headset spacers
31    Deda expander bung
230   S3 seatpost, uncut
-20   Less: excess post removed
19    S3 seatpost wedge
127   Selle Italia SLR Kit Carbonio
132   Sram eTap RH shifter
132   Sram eTap LH shifter
214   Sram Red eTap RD, no battery
136   Sram Red eTap FD, no battery
24    Sram Red eTap battery
25    Sram Red eTap battery
116   Red Aerolink rear brake, no pads
120   Red Aerolink front brake, no pads
31    Zipp Platinum Pro Evo pads (4)
70    FSA hybrid ceramic PF30 BB
3     FSA BB30 bearing covers
711   Rotor PowerLT 175mm with 52/36 Praxis Works rings
6     Rotor BB30 spacer (metal)
124   3T ARX II Team stem, 100mm
221   3T Aeronova Team handlebars, 42
236   Sram Red 22 chain + quicklink, sized
165   Sram XG1190 11-28 cassette
560   Vittoria G+ Corsa tubulars, 25c, x2
56    Zipp aero Ti skewers
850   Zipp 404 Firecrest tubular rear wheel
660   Zipp 404 Firecrest tubular front wheel
53    Velox 14 tubular tape
19    Nokon outer + liner, front
9     Sram brake cable, front
37    Nokon outer + liner, rear with anti-rub sleeves
15    Sram brake cable, rear
85    Elite Custom Race stealth cages (2)
208   Speedplay stainless pedals
5     Helitape (DS chainstay)
57    Fizik superlight 2mm bar tape
51    K-Edge Garmin mount XL
7053  Total
I assume the difference is rounding error (including my PT hanging scale only measuring to 10g accuracy, so the wheels and tyres are only really approximate) plus carbon paste, cable ends and other bits and bobs.
tmr5555
by tmr5555
58 frame size?
SLCBrandon
by SLCBrandon
Absolutely love the look of the S3 and especially that scheme. Pretty surprised by the frame/fork weight though.
Nixster
by Nixster
Looks great, I nearly did something very similar but went with a Supersix Evo instead. I thought the frame was sub-kilo in a 54 so I guess 1100g on a 58 is in the ballpark.
Tune those Speedplays with Ti axles bow ties and bolts, swap the bottle cages for Elite carbons and you'll be under 7kg, just saying...
