It’s Miller Time! Gotobike B36 with EPS and TRP Hy/Rd discs
Miller
by Miller
Jever98: cheers.
Some words about the Hy-road / HY/Rd brakes.
I'm running a 160 rotor at the front, TRP's own centrelock rotor to be precise. The flatmount standard assumes an adaptor between fork and caliper which can be flipped to allow either 160 or 140 rotors. Which is fair enough but it's a kludgy solution and I can see why Campag have chosen to go for a 160 only front caliper with no need for an adapter.
The first time I used the brakes... well not as much happened as I would have liked! These brakes really do need to be run in over a few hours of riding. With that behind me the brakes are beginning to have proper bite. Good braking with full carbon rims, everyone's got to like that.
One thing though, there is poor access to the upper bolt on the fork adapter with the Hy-road caliper. I've modified a hex key by cutting some length off the short end to have a key with a very short end. This allows good access to the fastening bolt.
There's a 140mm rotor at the rear. The rear caliper is bolted in place from underneath the chainstay which is very convenient, maintenance-wise.
These Hy-road calipers have been modified by replacing the stock actuation arm with one from forum member Joejack951. This clamps the cable inside rather than outside the bolt and is intended for brake levers such as those from Campagnolo that pull slightly less cable than current Shimano. The replacement arms are very nicely machined and very reasonably priced.
outnumbered
by outnumbered
I have seen this bike IRL and it is as nice as it looks in the photos. I'm still amazed that someone managed to spot the headset issue from the original pics. Some serious tech skills on here!
lwk
by lwk
Hi @Millar. Have you done some more rides? Can you tell how the frame rides and handles? Thank you
Miller
by Miller
Thanks for the nudge.
In 2013 I put together a disc brake road bike based on a CX frame. It has been an excellent machine for me, has introduced me to gravel events, but I well remember taking it out on a clubrun and one of the stronger riders glancing at it and asking: “Is it slow?”. As it happens, it wasn’t, but his question certainly expressed a concern about disc-braked bikes.
As much as I had a concept for this build beyond want-new-bike it was ‘fast road disc’. That and wanting to tick a few boxes like EPS shifting, hidden cables, thru axles, wider wheels, tubeless. Campag releasing their hydro groupsets was timely but the price was still too rich for me to go there although I look forward to seeing some H11 builds here.
Enough rambling, what does it ride like.
The main influence on ride feel is probably the tyres. These first gen Schwalbe Ones are weighty at 390g per but thecycleclinic.co.uk was selling them at a bargain £28. They give a very smooth and secure ride. I’ve settled on 60psi as being a good balance of comfort while avoiding the bounciness of lower pressure or harshness of higher pressure. On the bdop 26mm rims they inflate out to 29mm width.
My comparison bike is a 2012-era BMC SLR01. This Miller has slightly less snappy handling than the BMC, it’s more stable on rollers for example, but it’s absolutely as flickable as I need it to be. The brakes lead to a feeling of confidence while aboard, you know that light finger pressure will silently scrub off speed. On a brisk ride on damp roads a couple of weeks back, in a small group, we came to a surprisingly tightening bend. My friends both ran wide on exit but I was able to avoid crossing the white line and I did put that down to the braking. I love the combination of EPS and discs.
So, the tyres insulate me from the worst of the often crappy roads round here and being so robust would tempt me to mild off-road if I didn’t shudder at the thought of getting this thing muddy. And yes, the bike is fast. I feel it picks up speed very easily. On that same ride mentioned above I worried about being hindered but I soon felt quite the opposite, that if I was going to have to work, this was the bike to be aboard. It’s great out of the saddle, you press the pedals and go. I’m getting good averages and segments on Strava.
All usual disclaimers apply, I have not ridden every good bike out there, of course I’m going to big up the thing I’ve bought, but right now this Miller is my favourite bike to ride.
lwk
by lwk
Thanks for the reply. Concerning the weight of the bike, how is it on climbs? This is one of the best looking chinese framesets, just a pity about the frame weight
Miller
by Miller
It's great on climbs, especially when out of the saddle. This might not be the ultimate bike for Alpine climbs but you have to go down too; a spec like this is going to shine on descents.
I also found myself wishing the frame was lighter but it ticks a lot of boxes feature-wise and is nicely made and painted. My build list is not especially lightweight so it wouldn't be difficult to get a disc build into the 7.x kg range and would there really be anything to complain about then?
lwk
by lwk
Miller wrote:It's great on climbs, especially when out of the saddle. This might not be the ultimate bike for Alpine climbs but you have to go down too; a spec like this is going to shine on descents.
once again, thank you for your reply. Strangely I find that on my chinese cx bike out of saddle efforts seems to make the frame more responsive. That bike weighs 8.9kg with gravel tyres. I am using veloce groupset with Trp spyre brakes, so would definitely like something lighter that I can use for road racing and riding. Hongfu has a disc frame (088) same as the new 008 frameset, but don't think 28mm tyres will fit and not 100% convinced on their seatpost binder
joejack951
by joejack951
lwk wrote:Hongfu has a disc frame (088) same as the new 008 frameset, but don't think 28mm tyres will fit and not 100% convinced on their seatpost binder
The Hongfu FM079-F will fit 28mm tires and uses a regular seatpost clamp.
lwk
by lwk
Thank you. Have seen that frame. Also nice, but the fork/frame integration of millers bike is my favorite design feature
DHT
by DHT
I just saw this thread... love the look of the frame. is it a road frame or a gravel, or CX frame? I want to put an ultegra R8020 hydraulic discs on mine... 160mm rotors... I don't see this model on their website anymore. How much did it cost? I prefer a pure road bike this time... I already own a beautiful Bianchi allroad (ALU) 105 hydraulic and it weighs about 11Kg... 8Kg would be nice LOL. I'm also getting a Yoeleo C50 wheels with DT Swiss 350's
