Just Got Back after 14 Years...
tabl10s
by tabl10s
and I'm working on the third bike. I have an:
2016 Orbea Orca OMR w/D-A Di2
Vision Trimax 35's(just lost an eBay auction for Metron 55's)
S-Works Power Pro saddle
Zipp SL-70 Aero bar
Enve stem
FSA SLK 32 seatpost
Current FSA "K Force" brakeset
Look Keo Blade Ti's
7.21kg
2013 Wilier Zero.7 with same components except:
Ritchie SuperLogic seatpost
Roval CLX 50's
Sram e-Tap
Sram Red cranks/brakeset
Rotor cassette.
6.66kg(don't like that set of numbers, so another upgrade has to be made).
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
Marin
by Marin
I would make a list with weights and check if there are lighter components from other brands!
tabl10s
by tabl10s
I just purchased the Rotor cassette($$$'s)to swap out the RED version and went for Q-Rings "Quarbon" chainrings to aid the knees. To my dismay, I gained an ounce to the Wilier! I'll now look into a lighter cable housing for both the Wilier and Orbea.
As for the Rca, I'll look into the Ax Leaf saddle as a start.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
michel2
Location: somewere floating between here and the other side
by michel2
photo's or it didn't happen ! (-:
possibleweenie
by possibleweenie
tabl10s wrote:I just purchased the Rotor cassette($$$'s)to swap out the RED version and went for Q-Rings "Quarbon" chainrings to aid the knees. To my dismay, I gained an ounce to the Wilier! I'll now look into a lighter cable housing for both the Wilier and Orbea.
Hi there,
Quick question. How do you find shifting with the Rotor cassette? I was given one as a gift (currently using Dura Ace or Ultegra depending on need) and from what I'm looking at in the tooth profile I wonder if it's any good at shifting.
Thanks
tabl10s
by tabl10s
Hi there,
Thanks
All good. I'll purchase it from you if you don't want it.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
bilwit
by bilwit
First rule of thumb without sacrificing hoops/saddle/stem/crank/brakes or breaking the bank: you can probably save up to 200g by going WW on your QR & compression plug (Extralite Streeters @ 29g, $135, Extralite Ultrastar 3 @ 6g, $35 -- if you're a little wigged out by the design of it and want a more traditional plug, JRC's is 11g @ $23).
Beyond that, your gram-saved-per-dollar goes down the drain: on the Orbea you can save maybe ~250g by getting 40-50mm carbon hoops depending on which ones. Another ~80g by getting the same seatpost as the Wilier and from there you'll be sacrificing some functionality with the stem or bars (~50g saved by getting fizik cyrano 00, ~30g saved by getting MFCK or Extralite stem).
tabl10s
by tabl10s
bilwit wrote:
Thu Sep 28, 2017 11:54 pm
Went from just under 9.82 kg to 7.26 with the change to Roval CLX 64's, swapping out the FSA K-Force Light for Sram Red cranks(standard size added weight and changing to Jagwire housing. Cr Look Keo Blades heavier over Ti's which will be remedied soon. The Zero.7 still holding strong@6.66 kg's.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
tabl10s
by tabl10s
Tue Aug 29, 2017 8:49 pm
Hi there,
Thanks
Piece of cake.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
