Godzuki26's Wife goes aero - Felt AR FRD 48cm
53x12
by 53x12
godzuki26 wrote:Thanks Ryan! Yes I need to consider width for a smaller person. I appreciate the input.
Consider the Zipp SL-70 aero handlebars. I have them in the size 38cm and they are great. Narrow is aero.
jever98
by jever98
godzuki26 wrote:If I want to go absolute lightest and use the Clavicula SE, the crankset requires a heavier THM bottom bracket. The THM BB30 bottom bracket weighs 85 grams. The FSA BB30 bottom bracket that works with the SRAM RED crankset weighs only 42 grams.
Clavicula SE: 295grams + 85 grams = 380 grams
SRAM RED: 349grams + 42 grams = 391 grams
On the way to me is a full ceramic bottom bracket that weighs 34 grams claimed.
SRAM RED: 349grams + 34 grams = 383 grams
So from a dollar per gram perspective, there is much more value with the $150 (Ebay) I paid for the SRAM RED vs the $1500 I paid for the Clavicula SE.
Have you considered Specialized S-Works? Pretty light if I recall correctly
No longer in the industry
53x12
by 53x12
godzuki26 wrote:Here is the frame minus the rear derailleur hanger and the grommets. 1063 grams!!!! Ugh!!! Mediocre!!!!!! Very heavy and very disappointing for this size. I have seen AR1's in larger sizes which are lighter than this. Maybe I have an extra layer of clear coat? The only way to find out is to strip the frame down to bare Textreme. The Cervelo S5 is lighter than this. However, the Scott Foil is even lighter. As mentioned earlier, I wanted all cable entries through the top tube which the Cervelo and Scott do not have.
I've been trying to make sense of this as 1063 for a size 48 AR FRD doesn't make sense to me. I know it is true since you posted it, but still strange. The AR1 in a size 54 weighs around 1070g for the frame.
viewtopic.php?t=129091
Better bang for the buck to buy the AR1, then get the AR FRD seat post?
godzuki26 wrote:Hello everyone,
Rather than continue posting on Godzuki26 Wife's Cannondale Evo HiMod 48cm, I thought I would create a dedicated thread for this build process. I was able to pick up a 48cm Felt AR FRD frame. My thought was this would be the lightest aero road frame available. I recall seeing a video where a 56cm was weighed in at 895 grams.
You weren't wrong. Dave Koesel (SuperDave) did the weight on a YouTube video. But it was for the "raw" version of the frame in a 56cm.
Marin
by Marin
nb Aeronovas are flared and about 16mm narrower at the levers.
godzuki26
by godzuki26
@Jever98 - The S works crankset is a heavier version of the Lightning SL crankset. The arms and spyder are both heavier When individually weighed. They are pretty much the same cranks as Specialized uses Lightning's patent for their cranks.
@53x12 - I was hoping for a sub 850 gram frame after all stripped down. 983 grams bare is not what I expected. Yes I am confused too. I just need to make up the weight elsewhere :thumb up
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
jever98
by jever98
From my experience they aren't, only the coupling was the same up to 2016. The axle has always been shorter. Not sure about the relative weight to Lightning.
godzuki26
by godzuki26
The shorter spindle Sworks cranks are about 380 grams.
https://cerrol.wordpress.com/tag/specia ... z/page/13/
ImageFelt AR FRD
jever98
by jever98
You're right, mea culpa - just put some 175mm ones on the scales - 404 g with spider. I had kept them in mind as a light option for spider-PM use.
Imaking20
by Imaking20
Definitely better bang for the buck to buy the AR1 or AR2 but I would advise against swapping the post to anyone that actually wants to ride! The VM module in the AR1/AR2 post is the reason for the extra weight - it also makes the ride bearable. My AR1 was very close to the feeling of riding my SL4 Tarmac. My FRD was easily the stiffest ride I've experienced - moreso than 1st gen Foil, Venge, TMR01.
Current:
T2
Retired:
bikemaniack
by bikemaniack
How long does it takes you to remove the paint by sand papar???
53x12
by 53x12
Imaking20 wrote:Definitely better bang for the buck to buy the AR1 or AR2 but I would advise against swapping the post to anyone that actually wants to ride! The VM module in the AR1/AR2 post is the reason for the extra weight - it also makes the ride bearable. My AR1 was very close to the feeling of riding my SL4 Tarmac. My FRD was easily the stiffest ride I've experienced - moreso than 1st gen Foil, Venge, TMR01.
I agree. The AR1 is highly underrated. I know people complain about the under BB rear brake. Other than that, there isn't really much to complain about. Good price. Aero. Stiff. Comfortable. Ok weight considering the type of frame.
godzuki26
by godzuki26
My wife loves her DASH P3 saddle on her Cannondale. Unfortunately, DASH has discontinued many of their saddles including the M4 saddle I will be using for this build. I don't like the white "D" logo so I removed it.
ImageFelt AR FRD
godzuki26
by godzuki26
I am all stripped down and ready. Will the Textreme carbon look cool with the Madfiber's 12K carbon pattern? But, are Madfiber wheels aero? These are the tubuar version so I will not have issues with delamination.
ImageFelt AR FRD
SLCBrandon
by SLCBrandon
So weird that we had such different experiences with our AR FRD's. Seems like weights are all over the board too. I'm pretty sure my 56cm was ~1050g with bottle cage bolts and hangers.
godzuki26
by godzuki26
@bikemaniack - removing paint from a frame using sand paper is a royal pain in the ass. It takes time and gets boring very quickly. I would sand for about an hour a day after work. On weekends maybe 2 to 3 hours. I think this took me about 6 to 8 hours to sand everything after adding up all the time.
ImageFelt AR FRD
