2017 CAAD 12, 6320g, 999g frame
Here's my latest project; a 1x based on a CAAD 12 frame that I picked up earlier this year.
frame-- 2017 Caad 12 50cm-- 999g
headset-- stock cdale-- 65g
rd hanger-- stock cdale-- 11g
seatpost clamp -- stock cdale-- 12g
bottle bolts -- stock cdale-- 7g
cable guides-- stock cdale-- 6g
fork-- stock cdale-- 349g - cut but still have 15mm to trim off
front rim-- a force 33-- 482g
rear rim-- a force 33-- 480g
front hub-- carbon ti-- 62g
rear hub-- carbon ti-- 164g
spokes-- sapim cx ray-- 202g
nipples-- 22g
tires-- schwalbe one 25mm-- 468g
tubes-- avenir-- 169g
rim strips-- 40g
skewers-- carbon ti-- 98g
air-- 10g
front deraileur-- none
rear deraileur-- sram force short cage-- 169g
front shifter-- sram force brake only-- 117g
rear shifter-- sram force 22-- 151g
chain-- kmc x11sl 110link-- 227g
spindle-- cdale sisl2-- 98g
bearings-- stock cdale-- 51g
seals/spacers-- 9g
crank arms-- sisl2 170mm-- 232g
big ring-- wide/narrow 44t sisl2-- 98g
cassette-- pg1170 11-28-- 252g
front brake-- sram force-- 144g w/ swissstop flashpro bxp pads
rear brake-- sram force-- 138g
post-- hylix 25.4-- 175g
saddle-- fizik antares mg-- 207g
stem-- 3t are team 110 -6-- 124g
bar-- cdale escape hanger 40cm-- 178g
pedals-- tririg mercury-- 88g
cable-- sram gore-- 90g
cage-- arundel mandible-- 28g
tape-- fizik 2mm-- 90g
computer mount- garmin bar mount-- 6g
grease-- 2g
total--------------- 6320g /13.9lb
Few things to comment on. Wasn't intended to be a weight weenie build - there's really not a lot of light stuff on here, just the carbon ti hubs, sisl2 crankset, and i was surprised at the weight of the cannonade escape hanger bars. oh and of course the tririg mercury pedals, but i use those on every build. Since they've stopped selling them I'm not sure what i'll do moving forward. I wasn't going to remove everything from the frame when I weighed it but when it came out at 1042g I figured pull everything off and see if its 9xx.....
The fork is heavy though. I have an Evo HM fork that is 280 uncut...this was like 390 before I cut it. The Hylix post is heavyish at its uncut 400mm length but I can hack off like 150mm easy, and get it down to prolly 130g. I haven't done it yet because I am not sure I'm going to keep it - looking to see if I can get the clamp for carbon 7*9 rails. Tires, tubes, bar tape and skewers are really heavy too, just stuff I had laying around..I figure with a Kalloy stem, shorter post, Antares 00, and lighter tires/tubes/skewers and tape, I could be at 5.9kg/12.9lbs.
The 1x was something i've wanted to try, and i just did a 50 mile shakeout ride today and so far loving it. Completely silent drivetrain, and fantastic shift quality. I added the recommended extra 2 links to the calculated chain length and I think that contributes to why it's so quiet even in the 44/28 gear. Not a clutched RD, but I took it over some really bumpy roads and shifted and no drama; can't imagine this chain ever coming off..
This is my first set of alloys in years, and they're awesome; great braking with the ceramic surface, stiff, but super comfortable. Set up with 80psi.
I'm 175cm (5'9), 59kg (130lbs), saddle height 72.5cm (28.5").
nipples-- 22g
rim strips-- 40g
air-- 10g
seals/spacers-- 9g
grease-- 2g
Impressive weight. I don't think my 56 could ever compete with that
The 1x drivetrain is really interesting but a 44t chainring imo is not enough for flat and descent, I've seen that on official catalog the 1x caad12 was showed with a 50t chainring
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
garjo wrote:The 1x drivetrain is really interesting but a 44t chainring imo is not enough for flat and descent, I've seen that on official catalog the 1x caad12 was showed with a 50t chainring
It may not be. There's a ride that I do on Wednesdays where the finishing sprint is close to 65k; we'll see if i can hang. No problems hitting 50kph on it's test ride...
squid046 wrote:I bought a set of wheels from November a few moths back. I love them and the service from Dave was great. They're located about twenty five minutes from my house.
Yes indeed, I have a couple sets of the Rails and decided to try the a-force after going for a ride with Dave and having him expound on the virtues of alloy for a couple of hours lol
