beepbeep wrote:Simply beautiful, looks timeless.
I've always been a fan of Ritcheys but never ridden one. How's the ride?
I currently own a 90's Colnago Master and love the feel (fast, gliding, with a sense that it almost pulls me forward) - how does a Ritchey frame compare?
3Pio wrote:And how u find ur Master in more detailed way? What is ur other ride (for comparation)?
rheosibal wrote:@thizz I'd go for a 51, we have pretty similar dimensions
deanhall3 wrote:Marin wrote:Roel W wrote:fork and tire clearance (30mm instead of 28mm)
I have the gray frame, and it will already take a 30mm in the rear. They switched to beefier forks with more clearance for 2018, and despite the marketing bla I'm not convinced the frame has changed at all.
BTW, if you're looking for a size 55 (hard to find currently) you can PM me.
This greatly depends on what kind of rims you're running. On my old grey frame, I was running Hed Ardennes+ rims which are pretty wide. The rear would barely clear a 28mm tire, while there was no chance on the front. Of course, the tire would balloon up past an actual 28mm due to the wide rims.
For those of you that are wondering, this frame does have a slightly different geometry. Aside from the beefier fork that allows for more clearance in the front, the rear is also a tad longer. On a 55cm, the wheelbase is 996cm compared to the previous model at 988cm. I found this out the hard way as my chain I took off the grey frame when swapping over the parts ended up being too short for the new blue frame so ended up having to buy a new chain. Another change on this new blue frame is the shape of the inner chain stays. On the inside of the chain stays there are little indentations in the tubing which again is allowing for a wider tire to be run. I'll try and get a of photo of it and post it here shortly.
Regarding the beefier fork - I experienced a bit of shuttering under heaver brake loads on the older gray model's fork. With this newer model with the updated fork, I haven't had this happen once.
Hope this info helps!
Roel W wrote:Marin wrote:Roel W wrote:fork and tire clearance (30mm instead of 28mm)
Thanks but I need a 57. Tested a 55 and that's just a litle bit too small.
By the way: old model size 59 for 899€ available in Germany: https://www.bike24.com/1.php?content=8; ... =1000,4,34
Compared to the 1299€ of the new model, it's a good deal.
01.01.1970:Jagwire Elite link cable review | |
01.01.1970:Review: Elite Cannibal Bottle Cages | |
01.01.1970:Giro Trans E70 review | |
01.01.1970:Vittoria Rubino Pro 3 review | |
01.01.1970:Specialized S-Works Power Test |
