4.8 kg / 10.5 lbs MTB
BmanX
by BmanX
I am so curious to know what modifications have been done so that I might be able to use some on my 29er build. I might go single speed again with my custom all carbon conversion from Fibre-Lyte
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Asteroid
by Asteroid
SK5 wrote:11.4lbs with full 9spd drivetrain and bar plugs .
That's better, but that doggone saddle must go, no matter how light.
Probably the narrow bars, too, unless your rides on it never exceed a couple blocks.
Oldbie
bikemaniack
by bikemaniack
SK5 do your things,don't look at others
SK5
by SK5
Some more pics .
SK5
by SK5
Should have posted this above but anyhow :
Been working on this the last week . I have machined the death (as much as possible) all the components for the gears . Even the gear hanger has been machined and drilled (in the right places) to get it as far down as possible . 8 grams :) !!!
The cassette I have already machined and I am using the gold Extralite lock ring as it is deisigned for a 12t so fits perfectly . The cassette if you remember is by Ceradure (designed and made in the Netherlands) and is the only one of its kind that has a special ceramic coating . Not bad for a cassette that costs nearly 400 euros .
The derailleur (Campagnolo carbon) has been modified to death with carbon bolts and titanium parts . Delrin jockey wheels with full ceramics, logo removed and carbon machined down to finish the derailleur off . I forgot to weigh on its own but it is below 158grams . I also neatened up the oval I cut out the lever and I also cut down the release trigger lever too . I polished the screws holding the body and removed all unnecessary bits (it is a XT 9spd) . For anyone wondering how the derailleur and shifter work together then the ratio is 2.45 on the derailleur and 3.2 (if I remember correctly) on the shifter so the pull is slightly less on each click which meant I had to pull the derailleur in more using the tension screw and align it further up the cassette . It works anyhow .
I made my own custom titanium bolts (not the first time either) . One for the shifter and one for the gear hanger . Unfortunately because I don't have access to a proper machine I had to use the dyes so the threads are cut rather than rolled but it's all good .
Nokon carbon housing with Powercor liner and Powercorz blue gear cable . Mmmmmmmmmmm .
386grams for everything . To put it into perspective the XTR m9000 cassette alone weighs 328grams .
On the bike it brings it to 5200grams . For a MTB with a full drivetrain I think that is pretty mental . If I add the Lauf we are talking around 5800 but I really don't want to go down that route again .
BmanX
by BmanX
Does anyone that raced bmx not remember the uni seat. This is just a carbon version
BIG DADDY B FLOW
tabl10s
by tabl10s
burglarboycie wrote:
Fri Jun 23, 2017 8:49 pm
Am I the only one that thinks that is a complete dog!!
No! White cables on a black bike?.... Bwahaha!
2016 Orbea Orca OMR: 15.0lbs/6.804kg...😐 | 2016 Rca: 11.07lbs/5.048kg...😭 | 2015 Pinarello F8: 13.04lbs/5.915kg...😩 | 2018 S-Works SL6: 12.04/5.625kg... 😥
boubou76
by boubou76
Oh my god this is crazy 0_0 good job!
rexyi1990
by rexyi1990
seriously about the saddle?? That is crazy!
