Pan's Pinarello F8 Race Build 7.6kg (How do I get it lighter...?!)
Pan
by Pan
Hey guys,
I'm Pan. I've posted before asking questions or commenting here and there but I decided to make my own introductory build thread.
I'm making a race bike out of pure lust ... I really want this bike to be around the 15lb or 6.8kg mark. I'm crossing my fingers and I'm willing to invest in more carbon to get this done if need be. I'm not a hardcore racer, but I do enjoy a good sprint finish : )
- 2016 Pinarello F8 022 "Black on Black" Size 54cm
- Dura Ace 9100 Mechanical Groupset
- Dura Ace 9100 Stages Single Sided Power Meter
- KMC SL11 Gold Chain
- Look Keo Max Carbon Ti 16Nm
- Zipp 404 Firecrest Clincher Wheelset
- Vittoria Corsa Graphine 25mm Tires
- Swiss Stop Carbon Black Brake Pads
- Elite Custom Bottle Cages
- Fizik Performance "Tacky" 3mm Bar Tape
- Zipp Ergo SL-70 Aluminum Handlebars
- Zipp Service Course SL Stem (temporary)
- Fizik Aliante Saddle (temporary)
2017 Pinarello F8 Dura Ace 9100 @ 7.5kg
2013 Bianchi Infinito 105 @ 8.2kg
1982 Colnago Super Single Speed @ 8.6kg
Pan
by Pan
Image Image
The painted Pinarello F8 Dogma Frame Size 54cm 022 Black on Black weighs 1086g with paint.
The uncut ONDA fork weighs 414g. The weight of the removed piece of stem is 23g. So 391g total for the installed fork.
I'm rather disappointed at the Look Keo Blade Max Carbon 2's. They were advertised at 90g each but when I weighed them they were 97g each.
I don't know if it's worth uploading images of the individual Dura Ace groupset parts.
170mm 50/34T Crankset - 440g 170mm Stages Left Crank Arm - 183g
Image Image
STI Lever Right - 199g STI Lever Left - 201g
Image Image
Front Brake - 163g Rear Brake - 160g
Image Image
Front Derailleur - 71g Rear Derailleur - 158g
11-28T Cassette - 197g
Italian Threaded BB - 69g
Pan
by Pan
Okay guys ... how do I make this thing lighter. I put it all together and BAM 7.6kg (16.8lbs)
I need to lose 0.8kg
I'm recycling a Specialized Romin Evo Pro saddle from another bike at the moment which weighs 208g.
The Leaf II Plus ordered should be about 86g.
Handlebars? - Zipp Service Course SL70 Aluminum
Bartape? - Fizik 3mm Tacky Performance
Inner Tubes?
I know my 404 wheelsets aren't featherweights either nor are the Vittoria Corsa G+'s.
beanbiken
by beanbiken
Geez, my F8 with the AX wheels is just over 6kg with cages. My suggestions are tubulars, lightweight stem and bars. Of course a set of EE's, Fibulars and a THM crank is another way...... it's only $'s :shock:
Ahhh, coffee & carbon
Stormtrooper
by Stormtrooper
Titanium lightweight skewers, lightweight inner tubes if you want to use those wheels, shorten your fork. Lighter cables like Jagwire
Why such a short stem?
Madone69
by Madone69
very surprised at your F8 weight ... i also hope to slash some grams on my XR4- full gloss 53 with post & headset
Pan
by Pan
kgt wrote:Why such a short stem?
I had the 70mm stem lying around in my garage.
It'll take some time for the 100mm Most stem to come in but honestly it's heavier.
Pan
by Pan
Madone69 wrote:very surprised at your F8 weight ... i also hope to slash some grams on my XR4- full gloss 53 with post & headset
1.8kg ... Goodness. That's a lot of paint. Yeah. Italian Aero bikes are beautiful but heavy. The Countervail technology in the XR4 CV makes the Oltre heavier than the older XR2 model, I believe. My older generation Bianchi Infinito C2C is a bit lighter than the newer Infinito CV.
I'm trying to get used to the low position so I don't want to completely cut the fork tube either... Guess the weight will have to come off from the components.
Ok, then. 70mm stems are not for road bikes, that's why I asked.
Pan
by Pan
beanbiken wrote:Geez, my F8 with the AX wheels is just over 6kg with cages. My suggestions are tubulars, lightweight stem and bars. Of course a set of EE's, Fibulars and a THM crank is another way...... it's only $'s :shock:
What size is your F8? I thought mine was quite heavy too. Blah....
Stormtrooper wrote:Titanium lightweight skewers, lightweight inner tubes if you want to use those wheels, shorten your fork. Lighter cables like Jagwire
Zipp Aluminum SL-70 Ergo Handlebars 260g -> Zipp Carbon Aero Handlebars 240g ($275) = 13.75$/g
Zipp Steel Skewers 85g -> Zipp Titanium Skewers 65g ($80) = 4$/g
Stem - Zipp Service Course SL 70mm 110g -> Most Tiger Aero 1K Carbon 100mm 164g ($190) = +3.5$/g
Specialized Romin Evo Expert Saddle 277g -> AX Lightness Leaf II Plus -> 86g ($325) = 1.7$/g
x2 CarbonWork Bottle Cages 10g = $110
Specialized 80mm Presta Valve Inner Tubes 111g x2 -> Continental Race Light Inner Tubes 75gx2 (22$) = 0.31$/g
Gold Jagwire Elite Links Brake and Shifter housing 53+72 = 125$ Ordered
I can't believe I'm being this fickle with it and I haven't even put the cages on yet. Damnit.
I might as well just change out the wheelset because I know they're the heaviest part of the bike at this point.
Do I go tubeless or tubular??
Pan
by Pan
Np. Yeah. It looks a bit unfitting on the bike : / ... I was hoping to get a fit performed before ordering the stem.
zzmkdw
by zzmkdw
I have a 2016 white F8 with Etap, 404 NSW, the Most stem you showed and FSA K wing compact handle bars. I really didn't try to make mine light, just picked the components i liked and it came in at 15.5lbs for a size 54. That includes pedals, cages and an uncut steer tube. Your number seems off to me, but i guess the pictures don't lie. :noidea:
If your goal is to just get lighter i would move away from the zipp components. They are heavy. Also the most stem will force you to run the proprietary pinarello spacers, which are heavy. They look cool though.
Rogma84
by Rogma84
Deda Superleggera RS Cockpit .
Lightweight Meilenstein and a light Saddle like selle italia slr tekno and you nailed it.
Conti supersonic Tubes and Veloflex Corsa in 23mm
PSM
by PSM
+100
It ruins the whole build.
