Long time lurker (7 years) Here's my 2017 Cannondale Evo 2 eTap 6.7kg
KWalker
by KWalker
If you need some links I think I have a shit ton of mini i-links. Personally I always run segmented housing on brakes as it only increases the perceived power and in some cases I think improves outright power slightly. The pro teams used to take a strand of links about 1-1.5inch long, then a jagwire dual ended ferrule and hook that up to normal housing so the flexible elbow was at the headtube. The benefit there being that you don't need full liner.
Gramz
Failed Custom Bike
byron505
by byron505
KWalker wrote:If you need some links I think I have a shit ton of mini i-links. Personally I always run segmented housing on brakes as it only increases the perceived power and in some cases I think improves outright power slightly. The pro teams used to take a strand of links about 1-1.5inch long, then a jagwire dual ended ferrule and hook that up to normal housing so the flexible elbow was at the headtube. The benefit there being that you don't need full liner.
damn okay i want to get into this. i just need to get my hands on the jagwire dual ended ferrules then and now i can send back that expensive ass jagwire link kit.
good lookin out K.
2017 | Cannondale Evo2 eTap with 90's Cannondale Track paint | 60cm | ??kg
2017 | Cannondale Evo2 eTap | 60cm | 6.7kg
2016 | Valence Road+ Ti 1x11 Disc | 58cm | 8.35kg
Instagram: @byron505
