4ibanez's Supersix Evo - 4.42kg (build list in 1st post)
4ibanez
by 4ibanez
dereksmalls wrote:Was it the 1 1/4 45°x45° for the lower bearing? Can you link to the one on the Tredz site for the lower assembly? I'm going for a Cane Creek AER upper assembly so need something light for the bottom. My LBS is going to hate me when I walk in with my box of parts and say "swap everything out for this stuff please" :lol: :lol:
https://www.tredz.co.uk/.FSA-SL-Alloy-A ... 106244.htm
It's 1, 1/4, 45°x 45°.
Install it yourself. I'm still a bit of an amateur, but it only took me 10 minutes. You just need some grease and a torque wrench. I use a piece of wire if the expander falls down the steerer. I find it's oh so easy to fall in, but doesn't come back out!
PS what's the weight of the Cane Creek?
dereksmalls
by dereksmalls
Top assembly including headset cover is 12 grams, 34 grams all up including the bottom crown race and bearing
4ibanez
by 4ibanez
I got some Veloflex sprinters 22mm at 243g and 244g plus a pair of Lightweight 28mm valve extenders - 4g. Hmm both tubs almost 20g over claimed weight (225g). Well they'll still save me 50g+ and I think they're gonna look good. They certainly seem top quality.
I removed the old tubs. The rear was knackered and dried up, the front was stuck well and insanely tacky and hard to clean. I decided to completely clean up both rims with acetone and go from scratch - front took about 2 hours, and an hour for the rear (It's my first time)!
The tubs are stretched, extenders installed with PTFE and all ready to go with gluing tomorrow.
I'm not too sure about the best way to store the rims and tubs between layers of mastik. I have a load of hooks in the garage which could work...
4ibanez
by 4ibanez
Now 4,678g (edit: miscalculated - it's 4663g). First attempt working with tubs (rather than just riding). I'm reasonably happy... Back is dead straight, front has a bit of wobble.
burglarboycie
by burglarboycie
Hell yeah!! Looks so good
4ibanez
by 4ibanez
I've updated the 1st page to include the current build list. If anyone's interested I'll keep that up to date when I make any further changes.
4,663g is the current weight give or take a little.
Asteroid
by Asteroid
Looks fantastic. You could drop another 100 grams by using Veloflex Records. Mine weighed in at 190 grams each. 22c width and expensive, although I bought mine several years ago for less than $60ea. Most riders get less than 1,000km on a rear. Mine show some wear at 500km, causing me to predict about 1,000 at most.
Shoot, combine that with a straight block cassette, and it oughtta bring you below ten pounds! Freaky.
Oldbie
4ibanez
by 4ibanez
Thanks - yeh there's a few things I've thought of... I'd consider a Record on the front, and having a combo made of the saddle/post (I've moved the nose down since last pics). I might consider going to a 25t cassette, but it's nice to have a bail out gear if you're not feeling it!
4ibanez
by 4ibanez
Double post
jinnie799
by jinnie799
Well I found missing cassette weight. What kind of cassett that you using?
jinnie799
by jinnie799
Btw, updated picture is really good.
Denavelo
by Denavelo
You can always run the Omni Racer Cassettes and shave some grams there.
My buddy is a hammer and rides one, and that cassette is solid and pricey.
Having a Tubular hop "Wobble" is like nails on a chalkboard to me. I've been running tubs for years and straightening / centering the tire comes with experience.
You'll get it down and the timing you have to center the tire before the glue mends.
Spin the wheel close to your eye and look for the uneven area and move it to the Left/Right. Once you get all of the hops out, then roll it on the floor with all of your weight and the tire at about 80psi. I roll the wheel back and forth a few times with lots of pressure.
You never really notice the hop until you hit a smooth patch of road, and then my OCD kicks in.
Speedvagen Road Machine "2011 Surprise me | Cannondale SuperSix Evo | Rob English "Mudfoot" 29er | Firefly Ti #419
Gearjunkie
by Gearjunkie
The other (just very slightly different) thing that I find helps center a new tubular is to do the roll around on low pressure when the glue is still new (as above) but also do that turning tight corners (circles) at the same time, do both directions, left and right turn.
I find this uses the natural stretch of the tire to pull it central.
Also pays to have a non WW skewer in to give you something solid to hold onto while you wheel it around. Obviously while the wheel is NOT on the bike :)
jinnie799
by jinnie799
4ibanez wrote:Now 4,678g (edit: miscalculated - it's 4663g). First attempt working with tubs (rather than just riding). I'm reasonably happy... Back is dead straight, front has a bit of wobble.
don't you have any issue for using clavicula se on this frame BB30A?
like sound or q-factor or shorter spindle problems..
I need your help to set up my new machine for 2107 CAAD12 black inc.
what did you use for bb? did you purchase THM BB for MTB PF30 or MTB BB30? as you know, from the manual those MTB BB are 73mm. it means doesn't need any spacer.
or not of the above options, let me know that which BB that you use and spacer as well.
help me dude. :D :thumbup:
AZR3
by AZR3
His is a 2015 Evo, pre BB30a
