Filament Bikes
mvnsnd
by mvnsnd
totalcompactroad wrote:lovely paint job on that
Totally agree, that black on orange is really nice!
craddock
by craddock
Here's my latest custom carbon creation. This will be built up with SRAM eTap HRD disc.
ImageFilamentSide by Filament, on Flickr
ImageFilamentFront2 by Filament, on Flickr
ImageFilamentAxle2 by Filament, on Flickr
ImageElephant by Filament, on Flickr
MAsshole
by MAsshole
Beautiful bike.
AZR3
by AZR3
Another beauty!
burglarboycie
by burglarboycie
Absolutely stunning!!
corky
by corky
Best so far :thumbup:
michel2
Location: somewere floating between here and the other side
by michel2
awesome looking bike !
you mind sharing the details like size/tubing/weight ?
thanks,mick
havana
by havana
Awesome. They only thing I would like is a tapered HT. Is that possible?
Most "innovations" in cycling are solutions for non-existing problems.
craddock
by craddock
michel2 wrote:awesome looking bike !
thanks,mick
Hi Mick. Thanks for the kind words.
It's a 56cm frame weighing 950g.
The tubes are custom rolled to my spec by a dedicated tube company in the UK using unidirectional high strength fibre prepreg.
The BB shell is PF30 format made in-house to the correct spec for zero creaks. The BB shell is a complete tube with a good wall thickness rather than the thin partial flanges that I see on some frames.
Press fit done correctly is reliable and quiet.
The calliper mount is flat mount format and I'm using a 12mm thru-axle. The rear hose enters at the top of the down tube and is internal all the way to the chain stay but doesn't go through the BB shell. It's also fully guided and sealed internally for quick assembly and to avoid water ingress.
Cheers!
craddock
by craddock
havana wrote:Awesome. They only thing I would like is a tapered HT. Is that possible?
Yes, I can do that.
BmanX
by BmanX
Very cool builds.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
craddock
by craddock
Next frame...
Unwrapping the BB shell after cure
ImageIMG_6190 by Filament, on Flickr
Smooth outside
ImageIMG_6196 by Filament, on Flickr
Smooth inside
ImageIMG_6195 by Filament, on Flickr
TT frame before wrapping the joints
ImageIMG_6176 by Filament, on Flickr
Hamfist
by Hamfist
Beautiful!
jever98
by jever98
What fork are you using on the disc frame? Nice work!
No longer in the industry
