Trek emonda alr stealth weenie project 6.8 kg target achieved now 6.60kg update
Fadec
by Fadec
This is the bottle cage I will be using.
Planet X carbon 22g actual weight 20g
Planet X bottle cage
Fadec
by Fadec
This is the seatpost I'll use Ritchie carbon superlogic 161g. 27.2mm dia
Ritchie carbon superlogic seatpost 161g
Fadec
by Fadec
11g generic seatpost clamp
11gseat post clamp
Fadec
by Fadec
Choice of saddles Selle italia slr carbon rails 142g, ti rails 151g or San Marco era composite 142g
Slr carbon rails
Slr ti rails
Fadec
by Fadec
The standard bontrager saddle = 262g
Bontrager alloy seatpost = 294g
Seatpost clamp =22g
Total = 578g
To be replaced by probably selle italia slr carbon rails = 142g
Ritchie carbon superlogic Seatpost = 161g
Generic clamp = 11g
Total=315g
Saving 263g
Running total weight saving to date = 1697g
Fadec
by Fadec
Next is handle bars and stem.
The original bontrager handlebar = 315g
Original st m = 143 g
Total = 458g
To be replaced with
FSA carbon force new ergo = 195g
Uno 7 90mm & ti bolts = 95g
Total = 290g
Saving 168g
Total saving to date =1865g
Uno 7 90mm stem
PSM
by PSM
I ordered a red alr 5 today. Will be my new commuter.
Fadec
by Fadec
You will not be disappointed with your choice I think the alr is a bit of a hidden gem
Fadec
by Fadec
Few more details
Fork uncut =339g
Steerer spacers = 24g
Topcap/ bolt = 12g
Expander = 27g
Bearing top cap = 14g
Bearing inner race/ retainer = 2g
Top bearing = 19g
Bottom bearing = 24g
The steerer spacers will be changed for
BBB carbon spacers = 11g. saving 13g
The topcap/ bolt and expander are the next place to loose weight
I will update when this happens
Total saving to date =1878g
BBB carbon spacers
Fadec
by Fadec
Target weight = 7.0 kg without pedals/ cage
Actual weight = 6.525 kg without pedals/cage
Build up nearly finished but needless to say I'm pleased
FLtrooper
by FLtrooper
Great results! Looks like 6.8 with Pedals and Cages?
Fadec
by Fadec
Right here we go
Pedals exustar eps-r fitted
Cage Planet X fitted
Garmin mount and garmin 25 fitted
Final weight = 6.790kg
6.790kg
PSM
by PSM
Good job.
You know you can remove logos on stem with aceton? Done that 3 times.
Fadec
by Fadec
Thanks I shall give it a go, I'm expecting a lighter steerer expander to arrive on Friday so I'll do it then
golfsierra
by golfsierra
Congrats on the weight, hoping to get there with my build in next couple weeks.
Which expander are you going with?
