Ultra light bike
Hi.
I present my new project.
My challenge is to reach 3 kg with materials and components known by many of you, to say that it is not a bike that I usually use, nothing more than for a ride since I have other bikes with components that do not suffer so much wear and tear on many of these Components and are safer for everyday use.
I hope you like it and I'll give you tips to keep lightening up, criticism and suggestions.
A greeting to all.
A greeting to all.
great first post! More info on build list, what you did to get it this weight etc would be useful
- Stolichnaya
Yoikes! Nice one.
Yes, a complete build list down to the bolts might assist us to provide better feedback.
We can only speculate with some of those photos, for example:
Are those standard hood covers? Or could you remove that weight and go with a lighter cover/wrap for the ergos?
First pic shows some apparent slack in the chain, could you remove a full link?
Looks great though. Finding another 200 grams will be a feat.
Impressive. 3.2kg on an FM-066SL. A build list with weights please.
Nice
Would like to see a build list as well.
Which fork is that?
Which fork is that?
Very interested as well. I am looking at getting an open mold frame for a sub 5kg build and any ideas always help.
I attach the list of components of my bike.
- Frame: FM066 SL size 54: 640 gr
- Fork: FM066 SL 1 1 / 8- 1 1/2: 223 gr
- Hedset: 28 gr
- bartape: Tesa 10 gr.
- Stem: Ax lightness Zeus 110mm: 63 gr
- Seatpost- sattel: combo Berk 98 gr
- Seatpostclamb: Carbonice 4 gr.
- Shifter brakelever: Sram red with hoods BTP and clamps carbon: 245 gr
- Brakes: Ax lightness AX 3000, schmolke carbon adjusting screws and power cordz mattias screw aluminum aluminum 105 gr.
- Pedals: Aerolite titanium 52 gr.
- Cranks: THM clavicle SE 172.5 compact 285 gr.
- Chainrings: Fybre Lyte 50-34 60 gr.
- Chainring bolts: Extralite 8 gr.
- Chain: Yaban Titanium 205 gr.
- Cassette: Mattias Hellore 11-23 78 gr.
- Rear derailleur: Sram red 105 gr.
- Front derailleur: Tiso with carbon plates Fybre Lite 38 gr.
- Handlebar: Ax lightness Ax 4000 compct 42 E / E 155 gr.
- Bottlecage: Work Carbon 6 gr.
- Tires: Tufo Elite Jet 110 gr 215 gr
- Wheels: Rims carbon 20mm (not marked), springs Pillar x Tralite ti, nipless Sapim aluminum, front Hub M5, rear Hub Extralite with ceramic bearings 542 gr
- Wire: Power cord 35gr
- Hedset: 28 gr
Interesting parts on that list. The wheelset sounds nice.
The bike looks great, and obviously that weight is very impressive!! What plans have you got to save a few grams next?
The weight of the frame and fork is pretty incredible. A check on HF website says the frame weight range is 780-920g; did they make it lighter previously?
Colnago C60 PLGL https://weightweenies.starbike.com/foru ... hilit=plgl
Fuji SL 1.1 viewtopic.php?f=10&t=140134&hilit=Fuji
- Juanmoretime
- Administrator
Has Tufo tires improved? While light they were always the worst at rolling resistance and road noise.
Excellent job on the build!
RESIDENT GRUMPY OLD MAN.
- Similar Topics
- Replies
- Views
- Last post
- 0 Replies
- 303 Views
Last post by swright
Fri Mar 02, 2018 4:52 pm
- 8 Replies
- 1211 Views
Last post by Mr.Gib
Tue May 22, 2018 5:04 pm
- 24 Replies
- 1602 Views
Last post by KotP
Tue Oct 09, 2018 1:58 am
- 8 Replies
- 999 Views
Last post by jacobeh
Thu Apr 19, 2018 9:58 am
- 1 Replies
- 399 Views
Last post by PrimO
Tue Apr 17, 2018 2:23 pm
