Colnago C40 'barn' find
Imaking20
by Imaking20
Bravo. The bike and story. Major kudos for the courtesy bar tape!
Current:
T2
Retired:
tids0009
by tids0009
The small details that go unnoticed in a bike build. The red anodized valves looked crap on this build so had to go. This is the before, during and after. once polished, put a small amount of clear 3M tape around the base of the valves so there was no rattle or annoying tick when riding.
boysa
by boysa
That is tremendous. I'd love to know the procedure you used. Dremel?
"Deserve's got nothing to do with it." William Munny
ManekiNico
by ManekiNico
tids0009 wrote:The red anodized valves looked crap on this build so had to go.
Now that is dedication!
But surely those valve caps are weighing you down? Something something rotational mass… :wink:
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
dj97223
by dj97223
Everything about this bike is pro . . . except the valve caps. :beerchug:
tids0009
by tids0009
boysa wrote:That is tremendous. I'd love to know the procedure you used. Dremel?
I did it the hard way and used sand paper, course at first then went finer and finished with wet rub, then used Autosol metal polish to get the mirror finish.
Unfortunately I have to run valve caps now so you don't see the red anodizing at the top of the valves as I have no idea how to get that off around the threads.
boysa
by boysa
Thanks! I love the three red lines, but I can see how it would be annoying regarding the part at the top of the valves. Nice work.
Bondurant
by Bondurant
A beauty; I'd love to own a bike like that
dj97223
by dj97223
Aren't those threads only for the valve cap? If so, then I guess it doesn't matter if you bugger them up a bit, but there probably is some dremel attachment that would work. The detail on the valve stem is a nice touch.
