Parlee Altum R eTap / R9150 Di2 / Record EPS / Super Record mechanical
guyc
by guyc
Pain. In. The. Arse.
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
RichTheRoadie wrote:Unfortunately, though, the rear one appears to emit a ticking noise when it has weight on it (by which I mean the noise can only be created when riding, not in the stand). Frustrating as hell, but I'm trying to get it resolved.
Well don't I feel like a bit of a tw4t...
I couldn't recreate the noise in the stand because the bike was clamped by the front fork, meaning the front wheel wasn't on the bike. In trying to eliminate a few options today I found myself nonchalantly tapping the front valve stem as if I had already decided "I know that isn't the cause but I'll check it anyway"...
Oh. :oops:
Still, at least the wheels are 100% now and I can get on with enjoying them and the bike in silence again! :lol:
Mr.Gib
by Mr.Gib
Yep, I was going to suggest you take a look at the valve stems. No need to :oops:, I am sure we have all done that or worse.
I have the same wheels. They are excellent. The one thing that shocked me was that out of the box, a few spokes were not tensioned properly - a couple were nearly slack (although the wheels were mostly round and true). Might not hurt you to check yours. Totally unacceptable from Mavic - hopefully my set was a rare example of bad QC. Fortunately, I am such a spoke tension obsessive that I check the tension of every spoke on a new wheelset and then again after a few hundred km. Doesn't matter how my wheels arrive, they will be perfect before I ride 'em.
I also have the same bike (and use the same saddle) in ML with Red mechanical. About 6.4 kg with the Mavics iirc. My paint job is essentially the Altum paint job applied to an Altum R. I think the frame was 850 grams. Thrilled with the whole package although that front wheel is really close - toe overlap is a bit extreme for such a large bike.
I should post an updated photo.
RichTheRoadie
by RichTheRoadie
Mr.Gib wrote:I have the same wheels. They are excellent. The one thing that shocked me was that out of the box, a few spokes were not tensioned properly - a couple were nearly slack (although the wheels were mostly round and true). Might not hurt you to check yours. Totally unacceptable from Mavic - hopefully my set was a rare example of bad QC. Fortunately, I am such a spoke tension obsessive that I check the tension of every spoke on a new wheelset and then again after a few hundred km. Doesn't matter how my wheels arrive, they will be perfect before I ride 'em.
Thanks for the warning, but no such issue here - had that have been the case they would have gone back for a refund as I can't tolerate such basic issues on wheels of this value, irrespective of how good the correctly finished product might be!
Mr.Gib wrote:I also have the same bike (and use the same saddle) in ML with Red mechanical. About 6.4 kg with the Mavics iirc. My paint job is essentially the Altum paint job applied to an Altum R. I think the frame was 850 grams. Thrilled with the whole package although that front wheel is really close - toe overlap is a bit extreme for such a large bike.
Great minds... :wink:
Again, though, no such issue for me in size 43-44 shoes - even despite tending to run my cleats as far back as I can (on standard shoes). I do get overlap, but I've known worse, and it's only ever at really slow speeds anyway (a blanket statement which applies to most toe overlap, in my opinion and experience).
Mr.Gib wrote:I should post an updated photo.
Yes, you should!
guyc
by guyc
Oh. :oops:
:thumbup:
RichTheRoadie
by RichTheRoadie
No updates - just a fresh pic:
Really quite enjoying this bike...
guyc
by guyc
Looks pretty much perfect
RichTheRoadie
by RichTheRoadie
Excess steerer trimmed and orange bar tape:
RichTheRoadie
by RichTheRoadie
Lighter non-Active version of the SQlab 612 Ergowave Race saddle drops the weight to 6.7kg (and the bar tape is now purple):
Wingnut
by Wingnut
Looks really nice there...maybe some EE's brakes and call it done?
"It's not the destination...it's the ride!"
RichTheRoadie
by RichTheRoadie
That's the rough plan, yes, although I have a set of anthracite sidewall Corsa tubs on the way to try as well.
I will continue to change bar tape because it's cheap fun; and the neutral frame colour carries most options quite well.
I'm tempted to try a different groupset too (from a purely aesthetics perspective - I just wish the eTap mechs weren't silver), but every time I think that then go for a ride eTap wins me over again.
Mr.Gib
by Mr.Gib
Really nice.
Is that the carbon rail non-active 612? Or the ti rail?
RichTheRoadie
by RichTheRoadie
Mr.Gib wrote:Is that the carbon rail non-active 612? Or the ti rail?
It's the carbon one.
Mr.Gib
by Mr.Gib
Nice, about 150 grams so a decent weight. Was the stack the same as the active model. I noticed that the active model with titanium rails actually has a lower stack than my non-active with titanium rails - about 5 mm.
RichTheRoadie
by RichTheRoadie
There seems to be a subtle difference in stack, with the non-Active version being 3 or 4mm shallower by my reckoning. The rails are a slightly different shape too (slightly longer at the rear on the non-Active, based on where my light mount sits with the saddle in the same place), which makes sense given the lack of the fairly bulky Active portion.
Thankfully it's no less comfortable than the non-Active version, which is a real result.
