2016 Cervélo S3 – eTap build
NIXvelo
by NIXvelo
Frame – Cervélo S3 size 54
Fork – Cervélo All-Carbon Tapered S3 Fork
Brake/Shift Levers – SRAM Red eTap
Brake Calipers – SRAM Red AeroLink
Front Derailleur – SRAM Red eTap
Rear Derailleur – SRAM Red eTap
Chain Catcher – SRAM Red
Cranks – Rotor 3D+ Compact 172.5mm
Bottom Bracket – BBInfinite Ceramitech
Chainrings – Rotor Aero Q-Rings 52/36
Chain – KMC X11SL
Cassette – SRAM Red 11-28
Wheels – ZIPP 303 Firecrest Clinchers
Skewers – ZIPP Titanium
Tyres – Schwalbe One 25mm
Tubes – Continental Race Light 60mm
Handlebars – 3T Aeronova Ltd Stealth 44mm
Stem – 3T ARX Ltd Stealth 90mm
Headset – FSA IS2
Seatpost – Cervélo Aero 2 Position Carbon
Saddle – Fizik Antares R1 Carbon Braided
Pedals – Speedplay Zero Titanium
Bottle Cages – Arundel Mandible Carbon
Bar Tape – Lizard Skin DSP 1.8mm
Cables – Jagwire Road Elite Link
Computer Mount – Fetha Garmin Faceplate Mount
ryanw
by ryanw
Lovely!
Just under 7kg?...
'16 Cervelo S5 - 6900g
'17 Focus Mares Force 1
'15 Scott Addict Team - 6850g Sold
'17 Cervelo R3D DA - 7580g - Sold
'16 Cannondale CAAD12 DA Disc - 7560g - RIP
SLCBrandon
by SLCBrandon
I like the S3 SO much more than the S5. Nice.
bencolem
by bencolem
That works!
SLCBrandon wrote:I like the S3 SO much more than the S5. Nice.
+1
ryanw
by ryanw
Maybe that's why Cervelo have made the 2017 S5 look like the S3?.. :noidea:
KCookie
by KCookie
Great looking bike, well done. !!
NIXvelo
by NIXvelo
Thanks all.
@ryanw... it turned out a bit porkier than I expected. I calculated it to sit around the 6.9kg mark when I was choosing all the parts... but the weight sits somewhere between 7.1-7.2kg mark. Was hoping to try and get it down to 6.9kg without using any exotic parts... 23mm rubber and Conti Supersonics might save 80+ grams... any ideas?
ryanw
by ryanw
Look at my build, supersonics save 50g straight away!
NIXvelo
by NIXvelo
ryanw wrote:Look at my build, supersonics save 50g straight away!
Thanks ryanw... you have a nice S5 build there... ordered the supersonics.
backside10
by backside10
Any issues with clearance between the etap front derailleur and the 3D+ crank arm? I've heard on some frames the lower limit screw hits the arm. Thanks
NIXvelo
by NIXvelo
backside10 wrote:Any issues with clearance between the etap front derailleur and the 3D+ crank arm? I've heard on some frames the lower limit screw hits the arm. Thanks
No issues at all.
GarethNightingale
by GarethNightingale
God I bleddy love this
prendrefeu
by prendrefeu
This is pulling up a thread from a while ago, but any chance you managed to weigh the fork prior to installation/cutting?
