Scott Addict DA Di2 Climbing bike - 4.48kg
keefzip
by keefzip
Hi All
This is my first WW build. Let me know what you think - thanks:
Frame Scott Addict R2 750
Forks Scott Addict R2 280
Expander plug Extralite Ultrastar 3 6
Top cap Extralite HyperCap 4
Bottom Bracket Rotor 4130 77
Seat post cap New Ultimate 77
Headset bearings Scott supplied 40
Stem Extralite 110mm stem 93
Handlebars Zipp Vuka Bull 218
Bar tape Lizard Skins DSP 2.5mm 5
Saddle Dash S.4 59
Crankset Lightning cranks 130 363
Chainrings RaceFace 38t Wide Narrow 59
Chainring bolts Praxis chainring bolts x 5 4
Chain KMC X11SL - Gold -114 links, but 6 removed 205
pedals Speedplay Nanogram 130
brake calipers EE Brakes inc Swissstop Prince pads 200
Shift lever left 6871 TT lever 64
Shift lever right 3T Aero 28
Di2 battery Dura Ace 9070 Di2 50
Di2 junction box Dura Ace 9070 Di2 4
Di2 wiring Dura Ace 9070 Di2 21
Di2 3 juntion Dura Ace 9070 Di2 16
Brake cables etc. Jagwire Elite 50
Rear derailleur DA 9070 Di2 214
Wheelset Extralite C32 CyberMax wheelset (F- 406g, R - 496g) 902
Tubular tyres Vittoria Crono CS 22 370
Tubular glue Continental 10
Cassette SRAM Red 22 (11-25) 156
Skewers Tune U20 skewers 22
Total 4.477kg
bikemaniack
by bikemaniack
Nice bike.
Change the wheels total weight 406+496 is 902 not 906
da123
by da123
Love it Tim, however if you can't make it to the top of Rose Hill in sub 7 minutes on that, I'm afraid you may be stripped of your SD Galactico status :)
Incidentally, I am extremely annoyed that I no longer have the lightest bike in the club as well. By about 900 grams!
Dave
keefzip
by keefzip
da123 wrote:Love it Tim, however if you can't make it to the top of Rose Hill in sub 7 minutes on that, I'm afraid you may be stripped of your SD Galactico status :)
Dave
Oh the cheek - I've already got my sub 7 minute badge, thank you :-)
You still have the title of "lightest bike with drop handlebars" :-)
da123
by da123
Dave
Oops, my mistake. Sub 6.45 then...
Valbrona
by Valbrona
Looks like a hill climb bike project. Not sure how it would fare up a proper climb.
Marin
by Marin
Valbrona wrote:proper climb
As in
BmanX
by BmanX
The build is nice and I like the options you have used. There are lighter options and cheaper options for the handlebars but I assume you had most of these parts.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
keefzip
by keefzip
Valbrona wrote:Looks like a hill climb bike project. Not sure how it would fare up a proper climb.
Not sure what you mean by that...It rides virtually the same as my Scott Foil. Same stack / reach, same handlebar height etc...
Whilst being aimed as a hill climb bike, if I run it with a 50T front chainring, I can (and have) ridden it on long rides.
keefzip
by keefzip
BmanX wrote:The build is nice and I like the options you have used. There are lighter options and cheaper options for the handlebars but I assume you had most of these parts.
Out of interest, which components do you think could go much lighter? I'm not talking saving a few grams, here and there. I was only interested in going sub 4.5kg. If I was aiming for a true hill climb bike, I could so a single speed version of this build for well sub 4kg.
The wheels - not much and, to my knowledge, nothing out there is lighter with wide rims.
The tubs - again, there aren't many lighter that are actually durable. No point using track tubs.
The handlebars - well, that's an interesting one. I selected the Zipp bars, because they were the lightest TT bars I could find. When aiming at a Di2 build, the lightest Di2 shifters are the TT ones - by quite a long way! Using TT bars also allowed me to use a very light left brake lever - the 3T TT lever. Overall, the combined weight of the bars, left and right lever are - I think - pretty much the lightest Di2 solution. I also managed to remove quite a bit of weight from the bars with sensitive Dremeling. The only way you can go lighter would be to use very light drop bars, but cut them and turn them upside down. Wasn't interested in that solution.
Cheers
Tim
BmanX
by BmanX
Here is a much lighter bar.
HYLIX Carbon BULLHORN TT Handlebar-155g
That is about 25% lighter.
BIG DADDY B FLOW
