Daily fixed gear bike
Armisas
by Armisas
Once i had sub 6kg bike and since then i can't ride anything heavier than that.
Right now i have this thing:
Frame:
Dolan Pre Cursa 58cm
Fork/Headset:
Alpina/Alpina
Crankset/Bottom Bracket:
Rotor track/Rotor track
Pedals:
Look S-track
Drivetrain/Cog/Chainring/Chain:
Miche 17t/Token 52t/KMC510HX
Handlebars/Stem:
Cube
Saddle/Seatpost:
no name carbon
Front Wheel/Hub/Tire:
Gi cycles prototype/mack/Vittoria rubino pro
Rear Wheel/Hub/Tire:
Weight is 7.8kg as it is.
Goal is a sub 6kg if i am very lucky sub 5.9kg. There is one problem tho it should take the daily beating in any wheather conditions. So no tubies and flimsy components.
So stay tuned.
robobiking
by robobiking
nice looking bike :thumbup:
https://robobiking.wordpress.com/
Test & Story Blog for all kind of cycling stuff
Cannondale F600 tuned (9kg)
jekyll man
by jekyll man
Could be struggle to get it light :-/
Frames a porker, and track stuff tends to be heavy (strong).
Its a sweet riding frame though, far better than it should have any right to be :)
Official cafe stop tester
Armisas
by Armisas
jekyll man wrote:Could be struggle to get it light :-/
Not keeping much of the current build ;) as well as my wallet content.
Expectations:
Dolan seta 58cm / 1200
Alpina Fork / 480
Ritchey WCS Carbon headset 8.1mm / 100
Tune Carbon UD Ahead Cap / 5
Superlogic Evo Curve Handlebar 40 / 200
Mt Zoom Seatpost Clamp / 6
Superlogic 1-bolt Seatpost 31.6 / 170
SLR kit carbonio Nero Puro / 130
Rotor Track bb / 119
Rotor Track Cranks 170 / 579
Sugino Zen Chainring 52t / 130
Flybikes Tractor Chain / 250
Miche Track Cog / 50
Gi cycles wheelset / 1660
Veloplugz / 6
Maxxis Flyweight Tubes / 120
Michelin Pro 4 Service course v2 / 420
Look S-track Carbon-ti / 250
Fizik Softtouch / 70
EDIT: Superlogic C260 / 120
Total / 6065
JoeFlan
by JoeFlan
I would recommend to use a stem in this build :smartass:
But to be serious, I'm sure you would be able to build up a set of mack hubs laced to low profile carbon rims or light weight aluminum rims for a wheel set that will be sub 1500g
Current Steed
Supersix Evo 6.25kg
Giant TCR SLR 6.8kg
Past Lovers
Focus Izalco Pro
Cervelo S1
Armisas
by Armisas
JoeFlan wrote:I would recommend to use a stem in this build :smartass:
Oh snap :(
Ritchey superlogic 110mm +120g :/
Im going to stick to my current wheels with a bit of upgrades. It should look good too :D
I also have a plan b - full carbon drug inc. fork / 350g uncut
