Hongfu FM079
Klaster_1
by Klaster_1
The bike gained some more grams, I had to replace broken CF tension pulley from eBay with stock one. I've already glued CF pulleys once, maybe I'll try that again, but messing around with dirty drivetrain was too much for today. Another change was a new 50t Fibre-Lyte chainring, my previous one lost a tooth to a curb, which rendered 50/12 noisy and 50/11 straight unusable. No fun jamming/dropping a chain going down at max speed. The issue was fixed, now on 50/11 the chain only rubs FD slightly every several rotations, should be good enough. I did not get the opportunity to weight crankset parts before, so here you are. Those male chainring bolts are steel, so I ordered a set of aluminium KCNCs. The Zipp manual mentions that "you'll need 5mm and 6mm hex keys to work the bolts", but female ones clearly require a chainring bolt tool, I think those aren't stock. I wonder if the person I bought these from still visits WW.
Fibre-Lyte Zipp VumaQuad 50t chainring, lightweight 2
Fibre-Lyte Zipp VumaQuad 34t chainring, lightweight 2
Zipp VumaQuad chainring male bolts, steel
Zipp VumaQuad all of chainring bolts and a spacer
Klaster_1
by Klaster_1
Back to a spare RD-5800 😂 Now I have an excuse to get an RD-R9100.
Squashednuts
by Squashednuts
Klaster1 wrote:
Sun Jul 22, 2018 9:15 am
Back to a spare RD-5700 😂 Now I have an excuse to get an RD-R9100.
Looks nasty, what happened?
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Klaster_1
by Klaster_1
Squashednuts wrote:
Sun Jul 22, 2018 9:20 am
I think the guide jockey wheel unglued from bearing and moved to the left, I shifted down at crossroad and stopped, when I resumed movement the chain jammed between the jockey wheel and RD cage, then a loud pop and rear wheel stopped moving. Last ride the same happened, that's why I put the stock tension jockey wheel back. That was super stupid of me, I didn't think about what actually went wrong, I should have replaced both jockey wheels to stock. At least this happened 5 minutes into the ride, so I walked back home, grabbed my MTB and went for a ride. Whoever uses the same J&L wheels from a couple years ago, be careful. Carbonice pulleys look nice, any other suggestions?
Klaster_1
by Klaster_1
Apparently, RD-5800 and RD-9000 cages have tension spring hole on opposite sides of axle, so I decided to play it safe and just put RD-9000 pulleys and inner cage plate on RD-5800. As I was afraid, the right dropout received some cosmetic damage. About 10 of chain links are bent to various degree, which makes it too short for any of my bikes and I don't have enough of master links yet to piece something more usable together from links left after the initial chain cut. I ordered a couple of new PYCs, a RD-R9100 SS and two sets of Carbonice pulleys while at it.
PYC SP1101, bent
PYC SP1101, bent
Dropout damage
Dropout damage
TARE
by TARE
And a crack on seatstay tube maybe?
Klaster_1
by Klaster_1
TARE wrote:
Mon Jul 30, 2018 10:33 pm
Nah, that's electrical tape to guard against RD cable housing.
Klaster_1
by Klaster_1
Turns out Carbonice pulleys aren't compatible with RD-R9100/RD-M9000 because of pulley bolt shape/thickness, despite claimed "can be used for all 9, 10 and 11 times cogsets". No lightweight pulleys for me until alu bolts from eBay arrive in several weeks. At least I dropped several grams from chainring bolts and RD housing (RD-R9100 needs less). I reused XEX-SL instead of heavier OT-RS900, the bend wasn't anything special given 12cm between chainstay housing exit port and hanger bolt.
Zipp (?) chainring bolts weight, 3pcs
KCNC chainring bolts weight, 3pcs
Shimano OT-RS900 weight, uncut, 24cm
Jagwire XEX-SL weight, ~22cm
New parts installed
New parts installed
Klaster_1
by Klaster_1
RD-R9100 shifts great and KCNC chainring bolts did not cause any issues yet.
Klaster_1
by Klaster_1
Today I went for 95km long, 1550m elevation ride to the nearby dam, whole path is along Yenisey river. Surprisingly, nothing broke and I even made it before dark. I don't usually ride so far due to lack of courage, maybe this ride will help to muster some of it and explore other places around my hometown. All photos have EXIF intact, so you can view location of each photo on a map.
At the bank in Ovsyanka village:
Yenisey river in Divnogorsk town:
At the bridge, close to the dam:
On the way back, bridge across Mana river:
Klaster_1's Hongfu FM079
One of the climbs, these were tough going back:
YangZili
by YangZili
I like the full black paint
Klaster_1
by Klaster_1
Today I picked a package with J&L aluminium pulley bolts. As I said earlier stock RD-R9100/RD-M9000 bolts are the same and don't work with Carbonice pulleys at all.
J&L aluminium pulley bolts weight
The other unfortunate thing about replacement pulleys was thickness, it's ~1.25mm too much, which leaves almost no pulley bolt thread exposed and the gap between cage halves gets too big.
RD-R9100 pulley thickness
Carbonice pulley thickness
Carbonice pulley spacer thickness (there are two per pulley)
Not enough thread
Not enough thread
Incorrect cage gap with stock Carbonice pulley spacers
To fix the issue, I wet sanded spacers down to ~1.71mm. The final weight came out as 150.89g. Because J&L bolts have thread where the inner race of pulley sits on, there's a bit of diameter mismatch going on and you can rock pulley extremes left/right regardless how much torque has been applied to bolts. We'll see how this affects the shifting. Another thing to note: J&L bolt head is thicker than Shimano counterparts, so guide pulley bolt doesn't sit flush with the cage surface; the tension pulley bolt hole is deeper, so no problems there.
Shimano RD-R9100 SS with Carbonice Hanni and Nanni pulleys (spacers ground down to ~1.7mm) and J&L aluminium pulley bolts
In the end, RD-R9100 (including shorter housing) came out ~4.64g lighter than my RD-9000 tuned with J&L parts and there are still some tuning opportunities left.
Klaster_1
by Klaster_1
Here's some small parts I weighted along the way. I wanted to weight cage tension spring, cage rotation limit bolt and cage axle bolt too, but let's leave these for another time when I have a reason to remove the cage tension spring ;)
RD-R9100 high limit screw weight
RD-R9100 high limit screw thread diameter (M4)
RD-R9100 high limit screw length
RD-R9100 low limit screw weight
RD-R9100 low limit screw length
RD-R9100 limit screws plate weight
Bolts I didn't remove, these are steel
Gary71
by Gary71
Magnificent thread and attention to detail. Thank you!.
Can I ask how you are finding the Workswell through axle fork? Does the bike track well through corners without any latteral flex of issues?
How does the bike ride?
I am looking for a through axle fork to replace my CAAD12 fork and this just might be the ticket.
I would appreciate your thoughts
Klaster_1
by Klaster_1
Gary71 wrote:
Sat Sep 15, 2018 10:40 pm
First of all, I can't give precise answers to subjective or hard to measure questions, like other, more experienced posters. The only road fork to compare is the stock Hongfu HF-FK166. Also take note that I changed a caliper and front rotor too (140mm solid Razor to 160mm alu-carrier Ai-neon), and a wheelset a bit later, which adds more variables to the equation. Regarding flex, I think the new fork contributes to a slight rotor rub during hard efforts, especially after heavy braking, but this does not occur often, so I'm not bothered by it. A combination of rotor size, construction and clearance should play a role in this too, maybe I'd encounter the same on another fork. When cornering, I do not notice anything different from the HF-FK166, but that also includes a winter between two setups to dull the memories, but I guess both are fine, I haven't seen any feedback about poor cornering for any open-mold road disk fork on WW. The bike rides pretty much the same as before upgrade, I'm glad I managed to find such a product, the weight and USD/gram are hard to beat. For more feedback, you might want to contact Ticlimax, who owns a complete WCB-R-093.
Your CAAD12 looks lovely, that shade of green is totally my thing, as you might have noticed from some photos in this thread. If dimensions match, I think 100USD plus shipping might be a reasonable price to try a not very widespread product out.
