Third Time's a Charm: Litespeed T3
RyanH
by RyanH
Ride a bike with Campy and Skeleton Brakes and you'll understand what brakes should feel like. Until then, it's a lost cause to explain.
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
pdlpsher1
by pdlpsher1
Not sure what you are referring to. You mean these?
by Nefarious86
How much lever throw do you run? I've found anything less than about 2/3 total travel will make them feel horrible.
Sent from my SM-G977B using Tapatalk
Using Tapatalk
RyanH
by RyanH
Hmm, I usually run my brakes close so probably no where near what you're suggesting.
Strava
by Nefarious86
That will be the issue with Shimano then, their leverage rates require some lever throw.
Using Tapatalk
glepore
by glepore
RyanH wrote:
Fri Jun 14, 2019 7:37 pm
A/C doesn't work at the moment so I've been without a/c for the past few weeks but except last week, it's been fairly cool in Socal. When I had to replace the fan belt I removed the compressor/belt as that is in front of the fan belt. If I make it through the summer alive I'll remove the rest of the a/c components otherwise I'll get it converted to 134a.
Regarding the stereo, I bought the car so that IT is the stereo.
Yeah. Lose the ac, it sucks when it works. Lose the front diff and shafts too. I'd post a pic of my 85 Carrera Targa (aftermarket turbo etc) but flickr is doa.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
Imaking20
by Imaking20
pdlpsher1 wrote:
Thu Jun 20, 2019 2:52 am
If you do go back to 9100 please ditch the Sram XG cassette. The Shimano cassette will give you the best shifting experience money can buy. I've heard people using Shimano cassettes on Sram groups because they can't get perfect shifting performance when running Sram cassettes.
I don't understand the source of your Shimano braking issues. Are you using factory brake cables?
This seems like a post for Paceline.
Also +1 on 9100 brakes feeling like wood. They prove that less deflection is only good to a point.
tonytourist
by tonytourist
Imaking20 wrote:
Thu Jun 20, 2019 5:18 am
More like Bikeforums :|
Nejmann
by Nejmann
Do you use the wedges on the etap FD? Never lost a chain in the front. All my problems was slow shifting in the rear and weird shifting sometimes (electronic)
Sold it for SR12 mechanical. So much better and as you say damn those brakes are the best.
glepore
by glepore
My etap shifts ok on the one bike its on, but it has a red crank. Thank god it does, because the high limit stripped on install.
MoPho
by MoPho
How about a weightweenie "titanium" car and Titanium bike? 8)
Both new toys to me
RyanH
by RyanH
@Mopho need a ride report. In retrospect, I'm kinda regretting not getting an Elise. They don't depreciate, handle on rails and barely cost anything to keep running.
Meanwhile, in Porsche land... Let's not go there...
Strava
Imaking20
by Imaking20
MoPho wrote:
Fri Jun 21, 2019 4:49 am
Both new toys to me
by Nefarious86
That Moots/Lotus combo...
Using Tapatalk
glepore
by glepore
Nefarious86 wrote:That Moots/Lotus combo... ImageImageImage
Yeah. Exactly. Are those Pa plates?
