Third Time's a Charm: Litespeed T3
RyanH
by RyanH
Last week about 200 people showed up for the annual Circle of Doom ride; a 100 mile ride with 10K feet of elevation and about a 30 mile climb. I wanted to keep my HR around 160 bpm so about 6 minutes from the top, I didn't go with the other two when they picked it up which is about where the below were taken. I finished the main climb 6th at an average of 4 w/kg for the 90 minutes, good enough for about 10th all time fastest time up that climb. Not a bad day for someone that isn't a climber.
Strava
godzuki26
by godzuki26
Wow those are some outstanding numbers. You don't even look tired in the pictures. It is nice to see someone pushing themselves on the very bikes they post on this forum.
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
KWalker
by KWalker
Strava link? What VAM? Instead of using HR why not just use a MMP curve power target?
Gramz
Failed Custom Bike
Delorre
by Delorre
Very nice shots :thumbup: And have to say, took a look at the ride on strava, and those are impressive numbers for such a long climb and not being a climber!! I managed to hit a little over 300w on a 19 minutes climb in september this year, and that was 'almost' flat out, nowing we still had to do 3 other shorter climbs after that, but on the main + 1 hour climb next day, (we took it more easy), I only got something like 250w Avg :oops: So I know what effort it is to sustain such numbers...for us, mere amateurs.
RyanH
by RyanH
@kwalker I wasn't aware of that model. My fitness is a lot higher than ever before so I had to guess what I'd be able to hold. I knew 4w/kg was what my friend held in the front group last year so I targeted that while keeping an eye on my HR and RPE. It was a little surreal as the group of 4 that I was with, me and the other were chit chatting until near the end when he picked it up. It's a long ride and even to the top you still have 2 hours of rollers while descending to contend with so I didn't want to over do it.
https://www.strava.com/activities/766974467
Strava
beeatnik
by beeatnik
^Dat World Famous Rose Bowl Aero Testing, doe.
Who did 4W/kg last year? The loud, little guy? And you beat your 2015 time by about 20 min, rite?
KUDOS.
Calnago
by Calnago
Those are great shots and impressive performance. Well done. Just get the photos unwatermarked. They look worthy.
KWalker
by KWalker
RyanH wrote:@kwalker I wasn't aware of that model. My fitness is a lot higher than ever before so I had to guess what I'd be able to hold. I knew 4w/kg was what my friend held in the front group last year so I targeted that while keeping an eye on my HR and RPE. It was a little surreal as the group of 4 that I was with, me and the other were chit chatting until near the end when he picked it up. It's a long ride and even to the top you still have 2 hours of rollers while descending to contend with so I didn't want to over do it.
There are many mean maximal power models in Xert and GC. Pacing by HR on an effort that length seems silly since your HR will drift a bit. Understood though.
260w AP correct?
Gramz
Failed Custom Bike
RyanH
by RyanH
280w. VAM was 1100 for last 50 minutes of the climb.
Strava
KWalker
by KWalker
Word, I was just mouse-overing Strava and it showed 260 including the dips. Why did you choose this bike over your others?
Is there a Strava for the winner? Curious as to their stats.
Gramz
Failed Custom Bike
RyanH
by RyanH
The main segment got messed up because we were standing around in it before the ride rolled out. Avg power was 282 with descending, rollers and all:
Here's the link to Seth's ride. He backed off and was in "cruise" mode after he dropped the short, loud one that beeatnik refers to. That was his third time doing that route that week.
As far as this bike over the others, I'll elaborate on that tonight when I have more than 3 minutes to myself. Today's been nuts.
Strava
KWalker
by KWalker
I figured something was up since there were so many dips early on.
Gramz
Failed Custom Bike
mrgray
by mrgray
surely 4w/kg for that eternity does mean you are a climber (if you want to be). certainly i was dreaming if i could get there (4 w/kg) i'd be able to ride race @ westhead (hilly course here in sydney) without getting dropped.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
KWalker
by KWalker
That doesn't mean someone is a climber at all. It's a steady state efforts and pure climbers can usually punch a bit. 280w is lower than the AP of many even flat Cat 3 road races I've done and right around or below (depending on weight) the NP of a standard cat 3 race if it's not slow and negative. Not that it's bad, but just providing perspective since a power for a duration isn't really a way to directly equate someone's phenotype as a rider especially if its not reflective of competition demands. Climbs in U.S. races rarely exceed 10 minutes and almost never 20 for amateurs and the gradient often is not high enough for weight to be the sole determinant. Even then at the Cat 1/2 level lots of winners on 'climber's courses' aren't won by climbers.
Gramz
Failed Custom Bike
RyanH
by RyanH
Fortunately, as kwalker pointed out, most of our races feature a climb that is less than 20 minutes in duration. I'm not a climber, as you can probably tell from the pictures, I don't have that build. A friend of mine, who I consider a climber type, was telling me the other day that I need to increase my 20 min power (on a w/kg basis) to be more competitive next season. I don't think I agree as our races aren't controlled by the climbers and me being able to hold around 5w/kg should be sufficient. His point was that they will be fresher at the end, but again, I don't see the small dudes winning the sprint at the end.
I should have a revised power curve to post up in the training section at the end of this week but it looks like my power is up 5% almost entirely across the board over my historical PRs, which means I'm finally out of the shadow of my 2014 season.
With respect to the Litespeed and why I chose it? In short, it's different. It's not an Uber bike that I will want to replace each year, it's classic with a modern touch. Something about titanium frames, visually, puts a smile on my face. Carbon is neat but feels ubiquitous and mass produced, all except the R5ca felt that way to me. The T3 is very similar to the R5ca, but better when sprinting due to the stiffer chain stays and fork. Overall, I'm enamored with this bike. It's not aero, or light, but the way that I look at it is that I don't want to be in a position next year where I need marginal equipment gains to win a race.
Strava
