Third Time's a Charm: Litespeed T3
Imaking20
by Imaking20
You should definitely try the Campy red pads on the CCU and Lightweights. Both are great. Red pads are probably the only reason I found LW braking acceptable.
Current:
T2
Retired:
RyanH
by RyanH
Red pads with CCU and 9100 brakes was the best carbon braking I've ever experienced.
Strava
KarlC
by KarlC
glepore wrote:
Wed Feb 07, 2018 3:12 pm
Of all the pads I've used ( Campy,Swisstop Black, Reynolds Power and normal, various asian, Zipp) I really prefer the Campy Reds.
I tried a nice new set of Campy reds for a few rides with my Reynolds Aero wheels, I found them to be ok but no where near as good as the new Reynolds Power pads.
Calnago
by Calnago
I only use the Campy red pads on my Boras but I set someone up with Lightweights and put on the Lightweight grey pads. I found them to be superb and was really impressed. Based on that ride I wouldn’t be swapping them for Campy reds, and that’s not even caring about whether the warranty was voided or not. Never tried them in the wet however.
RyanH
by RyanH
Yeah, as Cal mentioned, braking with the Lightweight gray pads are quite good and I didn't feel a need to try other pads. Enve is textured, which is why there's excessive pad wear. On my past Reynolds Power Pads set, I got about 7K miles out of those with various rims. Red pads seem to wear a little faster though as I wore through a set last year and I'm pretty sure they weren't used for a majority of the year.
Strava
glepore
by glepore
I have no issue with braking with my Lightweights - I'm trying to settle on a pad that I could use reliably and interchangeably with CCU's and Lightweights. I don't care about warranty, none of these wheels are in warranty, I bottom feed.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
Juanmoretime
Administrator
by Juanmoretime
I’ve used Reynold Blue pads on every carbon wheel I’ve owned and find the more than fine for all types of carbon wheels and last a long time. The only other pad I’ve used is Koolstop for carbon and while the braking was good they did wear fast.
RESIDENT GRUMPY OLD MAN.
by Nefarious86
The cheap blue pads from Wiggle work perfectly with the reynolds brake track. Wear fast but for the $ who cares, they're silent and stop predictably.
Sent from my SM-N950F using Tapatalk
Using Tapatalk
RyanH
by RyanH
Ah, love new wheels day:
Strava
KarlC
by KarlC
Cool set of stairs
RyanH
by RyanH
Quick outdoor snap. This depth looks good with the frame.
Strava
RyanH
by RyanH
Got some other goods today:
PYC Chain was a pleasant surprise to be much lighter than expected. Saved 24g over Red 22 for the same length:
AER Upper saved 23g:
Strava
by Nefarious86
Which PYC chain is that?
Using Tapatalk
1415chris
by 1415chris
Isn't it PYC SP1101 Super Light 11s?
glepore
by glepore
Keep us posted on the chain.
