Third Time's a Charm: Litespeed T3
Denavelo
by Denavelo
Goes to show that hub choice is key with wheel purchasing. I've gotten nothing but the best rolling feel from Alchemy, Tune and White Industries hubs. They roll like nothing else out there. I'm currently on a set of Tune hubs with Ceramicspeed bearing upgrades, and these babies fly!
That was my only gripe with the CCU wheels and Bora wheels. They simply felt slow and it wasn't my butt dyno measuring the feel. Like you actually had to pedal in sections my other wheels simply rolled with ease, especially my wheels with Tune hubs.
I'm curious about those Wheel MFG hubs which are essentially the Alchemy Elf/Orc hubs, which I should have never sold.
Speedvagen Road Machine "2011 Surprise me | Cannondale SuperSix Evo | Rob English "Mudfoot" 29er | Firefly Ti #419 | Kogswell 650b Rando | Crema Cycles "Duo"
stax
by stax
@RyanH, yes I am on the textured track and the first set of black prince lasted me 7 weeks or so- probably around 1000km in that time in a fairly hilly area of Melbourne, Aus. I found with the Enve pads I pulled harder on the brake- DA 9100- and got no more braking power. That changed completely with the black prince. It really is night and day. I left Enve pads on the rear as I rarely use it but can tell the Enve pads don’t wear at anything like the Swissstop or Tangente on my Zipps.
Gearjunkie
by Gearjunkie
Interesting to hear your comparison of pads.
Have you tried the Reynolds power pads with those wheels (Ryan or Stax)?
stax
by stax
I haven’t tried Reynolds- would you recommend them?
KarlC
by KarlC
stax wrote:I haven’t tried Reynolds- would you recommend them?
Yes as long as it the NEWER Reynolds power pads and not just the old Reynolds blue pads
Denavelo
by Denavelo
What if we're all being fooled and these pads are all made in the same place, but different buckets of dye?
glepore
by glepore
Denavelo wrote:What if we're all being fooled and these pads are all made in the same place, but different buckets of dye?
LOL
WRT the Reynolds pads, I've used both the normal blue and the power on the same wheels, and while there is some difference, it's not enough to justify the premium for the Power's imho.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
KarlC
by KarlC
glepore wrote: LOL
I found just the opposite to be true, and would agree with this review ......
http://aerogeeks.com/2014/04/29/reynold ... ds-review/
RyanH
by RyanH
I've used the power pads on many wheelsets and they seem to work well with most. I think the same goes for the Bora red pads.
I've also found that the Power Pads especially need a "break in" period with each wheel for about 100 miles to get up to full power.
I rode a very short ride today and dragged my brakes on purpose with the power pads and they are already better than the Enve pads. I'll report back after the weekend.
Strava
asiantrick
by asiantrick
RyanH wrote:I've used the power pads on many wheelsets and they seem to work well with most. I think the same goes for the Bora red pads.
I've tried the power pads but i'm experience a lot of brake dust after every ride, where no dust on the Campagnolo red pads. Are your experience the same?
RyanH
by RyanH
You're using Bora pads with Gen 2 Enve?
Strava
asiantrick
by asiantrick
RyanH wrote:You're using Bora pads with Gen 2 Enve?
No, i'm using Bora pads with Bora wheelset, and Fulcrum Speed. I tested power pads with FSE wheelset and I'm getting alot of brake dust. I ended up using the Bora pads with FSE set and it works fantastic. I wonder if anyone is experiencing the same brake dust issues with power pads.
syplam
by syplam
What do you mean by brake dust??
RyanH
by RyanH
Been super slammed with work the past two weeks but had a chance to spend 30 minutes to glue up some Vlaanderen onto the CCU to see if they were okay on the rim even though the Roubaix wasn't. They look quite big on these rims:
Don't have a ride report though as I had to end my ride early to get back to the office. :x
Strava
PinaRene
by PinaRene
Nice setup with the Vlaanderen tubulars, but enough clearance ? ?
