Third Time's a Charm: Litespeed T3
RyanH
by RyanH
I still have so much to learn from you before I can successfully embark on that endeavor.
Strava
RyanH
by RyanH
Sweet, it's here!
Weight isn't too bad @ 1,343g with hardware and SRAM PF30 BB (probably 1253 without BB):
Problem with the Fairwheel Generic Clamp. Seems to be undersized as it measures 34.0 closed. On the 34.9mm tubes, it has a gap of about 1.5mm:
Fairwheel said that's "normal" and said it was okay if I tried to clamp it down even though I was fairly sure it'd break. Sure enough, it cracked:
Strava
godzuki26
by godzuki26
Bummer on the clamp :( Hey what frame size is your T3? Is it a 54 or a 52?
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
RyanH
by RyanH
52cm. Gonna be nice and low.
Strava
Daddy yo yo
by Daddy yo yo
Regarding the clamp: have a look at Carbonice and Procraft clamps.
Here are others:
https://www.speedwareshop.de/SASO-Carbo ... schelle-UD
http://www.zoulou-bikes.com/MOQUAI-UMwe ... UD-349-5gr
There was one from Mcfk but apparently those aren't available anymore.
My contribution to more beautiful roads: - old - / - new -
sanandreas
by sanandreas
I have a Procraft clamp: https://www.bike24.de/p192041.html
It's way more sturdy than the Carbonice, which I had before.
Even with only 3 Nm it clamps very well.
Juanmoretime
Administrator
by Juanmoretime
Very nice weight on the frame Ryan. I'm using the Parlee clamp on my R320 for about 5 years now and no issues at all.
RESIDENT GRUMPY OLD MAN.
RyanH
by RyanH
I agree, the Parlee clamps work very well. I've had those on my past builds so I knew something was wrong immediately when I went to go install this. Unfortunately, Fairwheel doesn't stock Parlee clamps anymore so I took a chance with this one. I had to order a SRAM clamp on Amazon in order to get it by Wednesday to complete the build but I'll order a Parlee one later.
Strava
RyanH
by RyanH
After a failure in shipping on time by USPS and UPS simultaneously, I have all the parts.
Compact BB30 Red Quarq came in lighter than expected at 705 (about 55g less than a standard GXP Quarq):
Compact Quarq Spider @ 117g:
Sans rings:
For those curious, the spiders are the same so you can convert your GXP Quarq to a BB30 one:
SRAM Red Front Derailleur Hanger @ 19g:
And then we encounter the first problem: SRAM put a little shelf on it which Campy hits:
A little dremeling and we're all good:
Um, has anyone seen red 3T Ergonova LTD bars?
Everything about them looks right, and the weight is about right for 38cm bars @ 179g:
This is meant for the Foil since it's 1 1/4" but a -17 on this bike is too aggressive, so this'll temporarily go on the Litespeed:
And here it is:
I need to do a lot of cleanup on the aesthetics. Black Enve decals are sitting on the desk, the stem needs to be acetoned, I need to glue up my 27mm Paves on the 32s and I have replacement Litespeed decals coming from GB. I'll get a proper ride on it tomorrow but I took a spin around the block and I'm pretty sure I'm in love again with a Ti bike. They really are special. Being back on Campy reinforces my belief that Campy is special as well.
Strava
Fixie82
by Fixie82
I'll probably change my mind once its done but I actually don't mind the white Enve decal on this. Agree with cleaning up the stem, but I reckon white Litespeed downtube decals would look ace.
jekyll man
by jekyll man
Looks good Ryan :thumbup:
Official cafe stop tester
KarlC
by KarlC
Looks good with the RZRs
RyanH
by RyanH
I forgot to post about the Extralite UltraTop. When installing it, I was able to press it in by hand. The lip is only like 1.5mm. That, and the lack of a compression ring for the top compression cover (to keep the fork from moving about) was slightly discomforting. I've had UltraTops in the past wear a ring into my forks. So, today, I decided to eat 30g and put a good ol' Chris King InSet in that I had sitting around.
I trimmed the fork and I got a set of matte black Enve decals as well as a glossy set. Since I've done glossy before, I figured I'd go with the matte first:
Lost 7g by trimming the steerer:
Front end is looking a lot cleaner:
I got a 40 mile ride in this morning. I really like the setup and it's good to be back on Ti. I don't feel like it's lacking at all in the stiffness department. The oversized BB and HT probably bumped up the stiffness numbers a decent amount over the Xicon, and the rear chainstays look a lot more aggressive. I'm looking forward to putting a lot of miles on it over the weekend. Should be able to throw the kitchen sink of riding demands over the weekend. I'll post a ride report once I get a good feel for it.
Strava
godzuki26
by godzuki26
That is clean :thumbup: Looks like you are going to be super low. Awesome!
ImageFelt AR FRD
Fuchspk
by Fuchspk
Looks sweat :)
