Godzuki26 Wife's Cannondale Evo HiMod 48cm build [3.96 kg] or [8.73 lbs]
godzuki26
by godzuki26
Here is the big aluminum piece where I was able to shave off the most weight.
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
godzuki26
by godzuki26
The other aluminum piece.
ImageFelt AR FRD
godzuki26
by godzuki26
The plastic piece. This piece is identical on both models. Same mold, same holes, same everything except for the paint. On the 22 it is gloss black while on the 2012 it is a metallic glitter paint.
ImageFelt AR FRD
godzuki26
by godzuki26
Surprise surprise. This carbon parallelogram piece is also identical and can be interchanged between both models like above. I didn't know that.
ImageFelt AR FRD
godzuki26
by godzuki26
Big difference with the barrel adjuster. For the RED 22 it is an M6 thread.....An M6 fine pitch thread as I have now learned. On the 2012 it is held in with a c-clip.
ImageFelt AR FRD
godzuki26
by godzuki26
This piece is identical to eachother. Once again, interchangeable.
ImageFelt AR FRD
godzuki26
by godzuki26
The big spring......Identical and interchangeable.
ImageFelt AR FRD
godzuki26
by godzuki26
The smaller spring.....Interchangeable and identical.
ImageFelt AR FRD
godzuki26
by godzuki26
The pinch bolt.....Different!!
ImageFelt AR FRD
godzuki26
by godzuki26
The pivot bolt. They are interchangeable too.
ImageFelt AR FRD
godzuki26
by godzuki26
Helicoil spring.....identical.
ImageFelt AR FRD
godzuki26
by godzuki26
Wave spring....Identical.
ImageFelt AR FRD
godzuki26
by godzuki26
Limit screw M4x20......They are the same!
ImageFelt AR FRD
godzuki26
by godzuki26
Limit screw M4x15.....Same.
ImageFelt AR FRD
godzuki26
by godzuki26
The little screw that secures the derailleur spring in place. They are the same.
ImageFelt AR FRD
