Godzuki26 Wife's Cannondale Evo HiMod 48cm build [3.96 kg] or [8.73 lbs]
godzuki26
by godzuki26
Thanks Kevin! That would be fantastic.
I just got my carbon rods in the mail. They feel light. I think I will save a couple grams and break 50 grams with the pins alone. I love these tiny incremental gains.
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
craciunptr
by craciunptr
Great stuff! WW is all about ingenuityand skill. I love the fact that you made your own spring! Proper masterful :D will you tackle a rear derailleur next?
godzuki26
by godzuki26
@craciunptr - you read my mind. The rear derailleur spring is longer. I could save an extra gram. Lol
ImageFelt AR FRD
godzuki26
by godzuki26
I got the carbon rods in the mail. They are custom made Toray 1100 carbon fiber from Japan wrapped in aerospace Boron carbon. Just kidding. It is from a hobby store online for $12. I think it is used in RC drones for added support or maybe even kites.
5 grams for these steel pins. There are actually 4 but I am starting off with 3. Lots of opportunity for weight savings here.
I cut these out and dremeled the channels. The 3 don't even register on the crappy scale. This is a win!
A closer look at my amateur handy work.
Every gram counts. I can shave this bolt down.
Yay. Doesn't register on the scale. Another "W"
I broke the 50 gram mark without the Fibrelyte front plate.
ImageFelt AR FRD
godzuki26
by godzuki26
As mentioned earlier, there is a 4th pin which is the longest in length and weighs almost 3 grams. I can save a minimum of 2 extra grams if I replace it. The only tricky part is the steel pin I need to replace is secured with micro sized C-clips. So, making channels for these little C-clips in the carbon will be a royal pain in the buttocks. I already cut the rod to the correct length. Now I need a micro sized saw to cut the channel.
ImageFelt AR FRD
RyanH
by RyanH
Your handiness with the dremel is getting impressively good. You need a better resolution scale for something like this. They're like $12 on Amazon for one with precision down to 1/100th of a gram.
Strava
godzuki26
by godzuki26
Thanks Ryan. Yes I definitely need a more accurate scale. I will be getting one. I ordered an assortment of 300 C-Clips online. I will find one from that batch that will fit the last carbon rod. The weight of the 2 C-Clips won't register on the scale. So, as of now I have the weight down to 46 grams. Hopefully another 2 or 3 more grams with the Fibrelyte front plate.
ImageFelt AR FRD
godzuki26
by godzuki26
Now, this back plate is massive in weight. Lots of opportunity to drop weight here. It is 4mm thick. I wonder what a carbon back plate would weigh?
ImageFelt AR FRD
craciunptr
by craciunptr
Probably half the weight, carbon density is 1,7g aluminium is 2.7g also bare in mind carbon is 10x tensile strength so less is required
kevosinn
by kevosinn
I just checked and I have a perfect piece of scrap plate. It's 3.85mm thick. You can have it.
godzuki26
by godzuki26
Kevin you are the best. Thank you so much. I believe I can the hit low 40 gram range with the back plate. Can I stop by some time to pick up the plate and drop off my handle bar and stem?
ImageFelt AR FRD
kevosinn
by kevosinn
Ya I'll be back working Monday if you want to come by. Shoot me a pm
Johnny Rad
by Johnny Rad
kevosinn wrote:I just checked and I have a perfect piece of scrap plate. It's 3.85mm thick. You can have it.
This forum is SO cool! Still cool. Always cool.
Ride strong, Weenies!
BRZeer
by BRZeer
Are you a Deceptacon? The purple. I get it.
Mep
by Mep
So... what happened to that weekend ride?
