Show us your CAAD12 frameset (non disc) builds
evan326
by evan326
ultyguy wrote:
evan326 wrote:How are you liking the hylix post? I have one on order, figured that it would be worth trying for the price. I have the same bike with similar plans. Got a new saddle, post is on order, wheels or bars are next
Unfortunately it's total crap, bad tolerances, lots of slippage, went back to the ugly Cannondale one :-(
Really? I've since gotten mine, using fiber grip it hasn't slipped at all for me. I've only had about 3 rides though, cold weather is coming....
What do you mean by bad tolerances?
wolfesquire
by wolfesquire
Ultegra di2
Roval clx 60mm Clinchers Wheelset
Ultegra Pedals
Everything else is stock
kervelo
by kervelo
kervelo wrote:I just purchased (ordered) a CAAD12 frameset , but it has not yet arrived. The colour is the same as the frame of @alexneumuller earlier in this thread.
I also ordered the Cannondale Save 25.4 seatpost for the bike, but the availability for it is in mid-December.
My frame arrived. Briefly opened the box and checked the weight
- size 58 frame with seat post collar 1180 g
- uncut fork 358 g
kervelo
by kervelo
I received the bottom bracket for my frame: Wishbone bb30a25c. I have yet to test the fit with my chainset, but the build quality seems to be great.
http://www.wishbonetw.com/product-1.php?id=31
I chose this part instead of the bbinfinite, because it can be removed easier, if needed.
SDCAAD
by SDCAAD
Pretty but pretty hefty still
RonnieGardocki
by RonnieGardocki
alexneumuller wrote:My Caad12 built with Enve Cockpit, SRAM Red, SRM Powermeter & HED Belgiums on R45 Hubs! Image
Hey Alex - great looking bike! Been thinking of the Red 22 crank for a caad12 I'm building up. Did you make the BB30 work in the BB30a shell? Or run a GXP crankset with a bb adapter?
Thanks!
alexneumuller
by alexneumuller
Thanks!
Thank you! Am running a GXP crankset with a BB adapter, as I had the SRM power meter from another bike and did not want to waste it! Was the easiest way, but got a ceramic bb adapter so that increased the cost again!
Parlee Z-Zero Disc
Stinner Frameworks Ti
Speedvagen 2017
Colnago C64
Independent Fabrication Crown Jewel TI
Felt IAFRD
Cannondale Super Evo Six 2017
Opencycle O-1.0
Open New UP 2017
Canyon Inflite 9.0 2015
grover
by grover
FYI, to install SRAM BB30 cranks on Cannondale BB30A just remove the 5mm spacer from the non-drive side before installation.
FLtrooper
by FLtrooper
grover wrote:FYI, to install SRAM BB30 cranks on Cannondale BB30A just remove the 5mm spacer from the non-drive side before installation.
Sir.. are you implying about the preload adjuster/spacer? I'm having currently having issues installing a Red22 BB30 on my CAAD12.
evan326
by evan326
grover
by grover
BB30A has 5mm extra shell width on the non drive side. So you need to make 5mm of room on the spindle on the non drive side to install the cranks.
If there is a 5mm spacer and a threaded preload adjuster. Remove the 5mm spacer and just use the threaded preload adjuster. This is the setup for Force/Rival/Quarq cranksets
If there is only the threaded preload adjuster, remove it and use only a wavy washer for bearing preload (plus some micro shims as needed). This is the setup for Red cranks (exluding Quarq)
If there is only a wavy washer, your cranks can't be installed (original Red, 10 speed Force/Rival)
wolfesquire
by wolfesquire
gsindela
by gsindela
wolfesquire wrote:Image
That is a beautiful bike!
2015 Storck Scenero G3, Force 22, Ultegra wheels, Zipp AL bars, stem, post
FLtrooper
by FLtrooper
X2... looks awesome!
Jopie666
by Jopie666
Wheels are a bit to deep for me. But looks very impressive. What are they? 80mm china clinchers?
Oh, it's all right. I'm sure that we can handle this situation maturely, just like the responsible adults that we are. Isn't that right, Mr... Poopy Pants?
