Spring propel
Raccooningtanuki
by Raccooningtanuki
FilmAt11 wrote:
Sat Sep 08, 2018 5:49 pm
I’m interested in the development of this bike. Light weight bolts and fender washers on the wheel covers are a good start. What are the flipper attachments on the seatpost? Does it appear like you’re emitting flames while seated? I bet they flap nicely in the wind.
They are the yellow petals of a sunflower. The sign of summer coming after spring. The tennis ball is the center of the sunflower. If I go back to 10 speed I can probably use a old trispoke or 575 in the rear. Clipped in it spins up and cuts through the air nicely
Spring propel viewtopic.php?t=140915
Fall guru merus viewtopic.php?t=155877
Summer carver nonsense viewtopic.php?t=156795
Raccooningtanuki
by Raccooningtanuki
halcyongolf wrote:
Sat Sep 08, 2018 6:46 am
Wait, slightly tight shoes is too much pain for you to deal with, but riding on a rounded piece of rubber on your taint for a 2 hour event is OK? You an I live in different worlds my friend. Buy a pair of Lake CX301 wides on sale which will likley help with the foot issue (and are super light) and good luck on that "saddle."
You can see my lake’s on page 2. Rounded price of rubber worked for a 170km stint. Just sit for downhill curves and dance the rest of the time. Zero drop cycling shoes would be nice though. Bought a pair of flypedals to try. The lakes weren’t unbearable.
JerryLook
by JerryLook
Curious why you are using the Thickslicks. Is the road debris really bad where you are, or are you using them for looks?
From what I have read, they are a very heavy tire, weighing something like 400-500 grams each depending on which version you have.
I’m sure you are limited on what white tires are available, if that is why you chose them.
I think the idea is pretty cool, using a bike as art. I’ve seen it done with older bikes, but not a newer road bike.
2010 Orbea Opal 54cm
5.97kg
Raccooningtanuki
by Raccooningtanuki
JerryLook wrote:
Sun Sep 09, 2018 4:49 pm
Originally for durability and because it’s the first white tire that showed up on my radar with. I have a white and yellow panaracer up front now. Vittoria’s Strada is also available in white which I have in yellow on the merus.
gurk700
by gurk700
I'll be racing this next month:
Raccooningtanuki
by Raccooningtanuki
gurk700 wrote:
Sun May 12, 2019 5:18 am
Tarmac’s design has changed quite a bit I see. :shock:
gurk700
by gurk700
Raccooningtanuki wrote:
Sun May 12, 2019 5:24 am
much.... much stiffer :D
