2016 Canyon Ultimate CF SLX w/ eTap
cnyn
by cnyn
You have to check with Canyon if they swap the Cockpit. Normally (I think) they don't but they said they will at some time.
Yes, I cut my steerer tube. All spacers are included and the tube comes uncut. There are 27mm spacers (look at the geometry chart).
My weight is 74+/- kg.
nonamed
by nonamed
cnyn wrote:You have to check with Canyon if they swap the Cockpit. Normally (I think) they don't but they said they will at some time.
So now You have all spacers under stem in total 27mm ? I Thought that there is also 15mm first transition spacer above headset so You can raise handlebar jn total 15mm+27mm ?
What is Your inseam and saddle weight? Were You fitted to this frame?
Wysłane z iPhone za pomocą Tapatalk
cnyn
by cnyn
It is 16 mm (cap) + 27 mm (spacers) - look here uncut version:
https://www.bikerumor.com/wp-content/up ... hts-03.jpg
But there is also a lower cap availiable:
http://cdn.mos.bikeradar.imdserve.com/i ... 60-540.jpg
I don't have my measurements here but look at the chart at canyon.com (Frame size, Height, Saddle Height):
https://www.canyon.com/en/road/ultimate ... sc-el.html
I think it's pretty accurate.
I used the PPS:
https://www.canyon.com/en/tools/pps/?bike_id=4081
and spoke to them at the telephone. I'm 1.77m.
nonamed
by nonamed
cnyn wrote:It is 16 mm (cap) + 27 mm (spacers) - look here uncut version:
Thanks for info!
Does Canyon provide both caps (lower and that 16mm) with bike?
cnyn
by cnyn
No. Just the 16 mm comes with the bike. You have to order the lower cap seperately.
nonamed
by nonamed
Would be grateful If You could measure Yours saddle height (from center of BB). Thanks!
cnyn
by cnyn
Update:
slake21
by slake21
cnyn wrote:Update:
black tape was better IMHO
sagatme
by sagatme
https://www.canyon.com/it/road/ultimate ... 0-ltd.html
New CF SLX... EVO.
A frame more light...
Inviato dal mio MotoG3 utilizzando Tapatalk
cnyn
by cnyn
more light & more expensive :D
here a better picture from yesterday:
maxsuo
by maxsuo
Good morning, what you have used in the empty holes left in the frame? I used the ones supplied in the classic frame kit Shimano 2 but they are ugly.
can you help me?
you can send me photos of the details of your frame?
thank you
cnyn
by cnyn
Did it like you. Ordered some grommets from Specialized and other ones but nothing fits very well. So I'm still searching.
philipjohnd
by philipjohnd
Nice build, I've just take delivery of the same frame and have started cabling up.
Could you fit a cable stop in the frame at the front end where the rear brake cable routes into the frame? The diameter of the recess doesn't look big enough to fit Jagwire ends?
Thanks.
cnyn
by cnyn
No problem with stock SRAM housings and also no problem with Nokon housings.
philipjohnd
by philipjohnd
cnyn wrote:No problem with stock SRAM housings and also no problem with Nokon housings.
Thanks for your reply, are they 4mm housings/links?
