Merida Reacto KOM
Jorisvc
by Jorisvc
I am riding the ultegra rear brake and can't get it any wider. My wheels are the Vision metron 55, probably they aren't stiff enough?
(original Reacto LTD DA 2017)
grtz
byron505
by byron505
love the build, including the tape.
looks straight mean
2017 | Cannondale Evo2 eTap with 90's Cannondale Track paint | 60cm | ??kg
2017 | Cannondale Evo2 eTap | 60cm | 6.7kg
2016 | Valence Road+ Ti 1x11 Disc | 58cm | 8.35kg
Instagram: @byron505
micky
by micky
@Jorivsc, get any other rear wheel to try as a test. Im not using Shimano brakes so no first hand experience.
@byron, cheers mate!
Leroni
by Leroni
@jorisvc, i v sold a reacto Ltd to a customer, the white one. Had the same problem
Brakes are not wide enough, the cable had almost no tension and the stock wheels are stiff as a rubberband.
A narrow rim solved the problem.
Sorry for interuption on your topic micky
Jorisvc
by Jorisvc
@micky did you already have issues with the sadle stem that lowers? and on how much nm do you tighten?
thx
micky
by micky
Sorry, Im not sure I understand correctly your question? Saddle stem?
Talking of saddles, currently I went back to my beloved San Marco Concor.
I will post a picture when I've time.
Bcoxa
by Bcoxa
I think they mean they are having issues with the seat post dropping, and are asking if you have the same issue, and how tight do you do up the bolt.
Jorisvc
by Jorisvc
Bcoxa wrote:I think they mean they are having issues with the seat post dropping, and are asking if you have the same issue, and how tight do you do up the bolt.
Correct, sorry for my english :-)
Jorisvc
by Jorisvc
double post
micky
by micky
Personally no problem with seatpost dropping.
I used the value reported on the seatclamp and never a problem.
