2015 Giant Propel Advanced
attesa38
by attesa38
i ve ever seen before nice propel advanced
efeballi
by efeballi
Thanks, I guess? Enjoy your 5% discount...
SHUT UP LEGS
2015 Cannondale Supersix Evo
2013 KTM Strada mod. (totaled)
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
efeballi
by efeballi
First ride today. Impressions:
-The aerodynamic advantage is noticeable. I don't have a power meter, but I felt just as fast as before, despite being quite a bit out of form.
-Very stiff; no deflection even when sprinting uphill in the small ring.
-Brakes not bad, swapping wheelsets could be a PITA but no problems at all, currently.
-Vibration and bump damping better than I expected, will report further after this weekend's long ride.
-I am SO out of form.
SHUT UP LEGS
nathanong87
Resident master of GIF
by nathanong87
cut your steerer pretty please.
nice bike.
efeballi
by efeballi
OH! I did. Photos to follow tomorrow morning.
Thanks, btw.
SHUT UP LEGS
efeballi
by efeballi
Who am I to disregard Nate's will, new pix with the steerer cut.
SHUT UP LEGS
Exar
by Exar
Solution to the cabling problem: use segmented housing (like i-links or Jagwire Elite links), they make a tighter bend.
Chains to the right!
Tomstr
by Tomstr
I was considering two of these ;)
Ride it like you stole it
efeballi
by efeballi
I'd probably go Di2 instead.
SHUT UP LEGS
Calnago
by Calnago
Yes, the routing for mechanical cables on those looks horrendous. That Avid Roller which @Tomstr posted two posts ago is obviously not applicable here lol but I've used those on some rear derailleur applications, like a touring bike where cables interfered with panniers, and a TT bike with a SRAM rear derailleur which would have otherwise required a huge loop to smoothly transition from the frame stop to the derailleur. They actually work really well for what they are intended. But I really wish manufacturers would stop with the derailleur cable routing entering the top tube like that. Or at least add a caveat like "works best with electric shifting". And like somebody joked above, it could also be really annoying while in the super death tuck.
efeballi
by efeballi
It makes me cringe that both aesthetics and shift performance is compromised by such awkward cable routing. It may work great with Di2, but guess what Giant, not all of us have enough $ for Di2 and not all of us are fans of Shimano(I am actually...) Venge ViAS and Trek M9 are on the same boat, it's just ignoring part of the customers' demands IMO.
SHUT UP LEGS
efeballi
by efeballi
Pulled the fork for head tube measurements. Looks like an OD2 fork would fit.
I also got some weights:
Giant Propel Advanced fork (cut): 580 g
Giant SpeedControl brakes: 110 g each, sans brake pads
Giant Contact SL 120 mm stem: 205 g
Giant Contact 2 110 mm stem: 185 g
Sent from my calculator using Tapatalk
SHUT UP LEGS
Alexmoreno
by Alexmoreno
Hey there!
A quick question... I saw you also did an upgrade to your headset cup (AKA bearing cover.).. I am looking for a similiar one since I want to slam down mine.
What model did you use?
Alexmoreno
by Alexmoreno
Hey there!
What model did you use??
efeballi
by efeballi
Hey,
I was using a cap from a kit that adapts a non-tapered steerer tube to a tapered head tube. Outer diameter 1.5", inner diameter 1.125".
I have also removed that and now ride the bike without any bearing covers. Bike slightly too big for me.
Sent from my Ultegra STI lever using gear cables
SHUT UP LEGS
