Scott Addict R1 Single Speed 3.39kg or 7.47lbs(FINISHED pg6)
jooo
by jooo
Everyone wrote:Bit of an aside but have you spent much time on the mack hubs? I'm tempted to get a set for my xc bike and I was wondering what people thought about them.
I'm not sure if it's still the same case now, but the older hubs used slightly modified Novatec freehubs IIRC. This is actually quite a good thing IMO. It means spare parts should be easy to find and the design has been pretty well proven on thousands of OEM wheels.
russianbear
by russianbear
Can't wait to see this all finished up. I've always thought a single speed like this might be a fun project.
Markmoddy
by Markmoddy
Liking this... Can't wait to see the finished bike!
prendrefeu
by prendrefeu
Bumping for updates.
godzuki26
by godzuki26
Hello everyone,
I am still waiting for the frame to be finished and returned. As soon as I get it back I will post some updates. In the mean time, I am thinking about sanding off the logos on the THM Scapula F fork. The silver logos wont match this build.
Thanks!
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
godzuki26
by godzuki26
I was able to gather some parts that I had sitting around in the garage to do a drop bar (standard road bar) configuration. I plan on using the straight bar set up, but wanted to see how a standard set up will look and weigh. The weights and specs are as follows:
SRAM S900 BRAKE LEVERS
BTP CARBON HOODS
BTP CLAMPS
ImageFelt AR FRD
godzuki26
by godzuki26
ZIPP SL HANDLE BAR 42MM OUTER TO OUTER
SANDED LOGOS OFF, TRIMMED ENDS
ImageFelt AR FRD
godzuki26
by godzuki26
EXTRALITE STEM
NEED TO USE THIS STEM BECAUSE I NEED IT FOR THE 31.8 CLAMP DIAMETER
ImageFelt AR FRD
godzuki26
by godzuki26
RECEIVED THE FRAME WITH HORIZONTAL DROP OUTS INSTALLED, LOGOS INSTALLED, CLEAR COATED, DERAILLEUR STOPS REMOVED, FRONT DERAILLEUR HANGER REMOVED
ImageFelt AR FRD
godzuki26
by godzuki26
A CLOSER LOOK AT THE TITANIUM PARAGON HORIZONTAL DROPOUTS INSTALLED. I AM VERY PLEASED WITH THE WORK. IT LOOKS FACTORY QUALITY AND SUPER CLEAN:)
ImageFelt AR FRD
godzuki26
by godzuki26
A CLOSER LOOK AT THE DOWN TUBE LOGO. PRETTY STEALTH JUST AS I REQUESTED. ALSO NOTICE THE DOWN TUBE DERAILLEUR STOPS HAVE BEEN REMOVED ALONG WITH THE INTEGRATED FRONT DERAILLEUR HANGER.
ImageFelt AR FRD
godzuki26
by godzuki26
HERE IS A BETTER LOOK AT THE HEAD TUBE LOGO. KIND OF HARD TO SEE BUT THAT IS EXACTLY HOW I WANTED IT. I LIKE TO SEE ALL THE CARBON UNDERNEATH THE CLEAR COAT. I COULD NOT BE ANY HAPPIER.
ImageFelt AR FRD
godzuki26
by godzuki26
HERE IS THE IMPORTANT PART.....THE WEIGHT. 782 GRAMS IS NOT AT ALL THAT BAD FOR A 2007 FRAME WITH AN INTEGRATED SEAT POST AND TITANIUM TRACK DROP OUTS.
ImageFelt AR FRD
Haydn
by Haydn
The work on the frame looks great, as does your track bike!
burglarboycie
by burglarboycie
The frame looks great. Excellent work.
