S-Works Tarmac 2015, Nibali Edition (7000g) - New pic page 4
- Resident master of GIF
- Contact:
that arione cx is well used
Finally receive my Arundel Mandible
Ti bolt with the bottle cage was 1g ligther than the s-works one, i decide to keep the black s-works
On another picture when the sun will shine and the temperature will be warmer .
Dalzhel wrote:cerro wrote:The Di2 cable goes at the same place as the brak cable goes into the frame. Is a small sleeve on the side there for the cable. and then in front behind the fork inside the frame and down to the bottom bracket.
Super cool paintjob that, got one of those hanging at work ready to be sold
LBS call me back to tell me that... wierd pattern, i will remove the brake cable and try
But looks really good with the Di2 cable like that, finished a Tarmac Kwiato yesterday with Di2 and looked really clean.
/jonas l
http://instagram.com/jonaslundb
cerro wrote:Dalzhel wrote:cerro wrote:The Di2 cable goes at the same place as the brak cable goes into the frame. Is a small sleeve on the side there for the cable. and then in front behind the fork inside the frame and down to the bottom bracket.
the time spent to pass the cable di2 worth every second when you look at the bike later , only two cable that goes beyond ... beautiful.
I took the time to weigh the bike with pedals, bottle cage and garmin mount, 6.8kg , not bad considering the context of weight and Di2 , with a saddle and stem I can decendre around 6.6kg without much wretched
The temperature looks more lenient for next week , I should be able to go outside without freezing my hands and take pictures in the sun.
Finally the temperature goes up and sun was out...
Not the most sunny day.
7kg with bottle cage, garmin sensor (magnetless) and raceware garmin mount
Built list:
Built list:
Very nice!
BTW I am impressed the frameset is that heavy (not that it actually matters of course...).
i am looking for a idea to replace the big shimano ti-wrap for the jonction box A
And another idea to attach the Di2 cable and the rear brake cable
Anyone ?
Anyone ?
- Contact:
tape job needs some work homie
+1 on tape job work. the cables look kinda messy too. use heat shrink tubing to wrap the wires and housing together. it'll be a lot cleaner
Instagram: joserheo
|| Mosaic RT-1 || Cannondale Evo || Cannondale CAAD10 ||
How is your bike shifting with the cable housing? Mine seems to be ok but not great. I have it adjusted about as smooth as it is going to be, but there appears to be some hang up in my lines no matter what I do.
bianchi10, his bike is di2
Instagram: joserheo
rheosibal wrote:+1 on tape job work. the cables look kinda messy too. use heat shrink tubing to wrap the wires and housing together. it'll be a lot cleaner
Want to do with the tape?
nathanong87 wrote:tape job needs some work homie
Finaly my New stem arrive.
Kalloy uno 100mm -17deg
