2014 Cannondale CAAD 10 (Updated 03/01/16)
Rheosibal - do you mind posting the pic of the chain stay routing - I have the Di2 fixings but the hole isn't big enough for the e cable- was just going to use a normal grommet but worth checking. Also, in the BB have you don't anything to hold the chain stay e cable away from the crank spindle? Any other tips great fully received - first time Di build!
Beancounter, I can email you a picture. The hole in the provided e-wire grommet for the chain stay is too small. You'll need to drill a hole with a slightly larger diameter and it'll fit right through.
In terms of the BB, the e-wire cables bend between the downtube, seat tube, and chain stay without any cable rub from the spindle. Just make sure they are tucked away neatly in each of the tubes without much play.
Good luck with the build!
Instagram: joserheo
|| Mosaic RT-1 || Cannondale Evo || Cannondale CAAD10 ||
Instagram: joserheo
Such a clean build.
That's very very nice.
mrtrinh wrote:Your bike makes me miss my caad10
Your Evo is an upgrade!
Instagram: joserheo
Wow I love it
Inviato dal mio GT-I9070 utilizzando Tapatalk
JBNX wrote:Great looking bike!
How do you use your garmin with those handlebar/stem combination?
Since the bars are oval, the best fit is with a barfly since they're plastic
Instagram: joserheo
