My SUPERSIX project THAT BLEW my budget (update 6-10-15)
WheresWaldo
by WheresWaldo
I was looking through the images posted and wondered about your seatpost clamp. I cannot find where Aerozine makes a 30mm clamp. Your SuperSix is a 2012, correct? What is the size of the seat tube at the clamp. My 2013 EVO is 30mm and a 31.8mm clamp won't work without a shim, so I am stuck with the Cannondale one or wait until Smud is back from wherever he went to get a carbon one cheaper than the $80-90 (this isn't even silly, it's a stupid price for a seatpost clamp), for the choices from Fairwheel.
paradawt
by paradawt
Will you change white area to pink?
Cannondale Supersix '10
tvillumsen
by tvillumsen
Its Chromatic Aberration, you can remove that in the Camera Raw Filter under Lens Correction.
PSM
by PSM
:lol: :frightened: Who wants a bike with CHROMATIC ABERRATIONS!?
Bianchi10
by Bianchi10
[quote="tvillumsen"]Its Chromatic Aberration, you can remove that in the Camera Raw Filter under Lens Correction.
Good to know!!! Thank you for that information!
oreoboreo
by oreoboreo
I think that pink and black look good together.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
Bianchi10
by Bianchi10
I do also. Hence my pink Rapha kit, but I don't want my white and black bike to look pink and white. Thank you Tvillumsen again for the info
Bianchi10
by Bianchi10
tvillumsen wrote:Its Chromatic Aberration, you can remove that in the Camera Raw Filter under Lens Correction.
I was able to go in and fix this to my original. What a difference. thank you!
Bianchi10
by Bianchi10
WheresWaldo wrote:I was looking through the images posted and wondered about your seatpost clamp. I cannot find where Aerozine makes a 30mm clamp. Your SuperSix is a 2012, correct? What is the size of the seat tube at the clamp. My 2013 EVO is 30mm and a 31.8mm clamp won't work without a shim, so I am stuck with the Cannondale one or wait until Smud is back from wherever he went to get a carbon one cheaper than the $80-90 (this isn't even silly, it's a stupid price for a seatpost clamp), for the choices from Fairwheel.
I'll PM you
Bianchi10
by Bianchi10
Been a long time since I posted up my bike. Couple small updates.
Took off the ilink shift cable housing ease it was just sub par. Left theilink brake housing on though. Shift housing I went with DA. Now using specialized Toupe Pro.
nickcube
by nickcube
Sweet bike dude! Seems like a really well built build spec too, where did you get that Garmin mount?
Bianchi10
by Bianchi10
nickcube wrote:Sweet bike dude! Seems like a really well built build spec too, where did you get that Garmin mount?
Thank you. I got the fliploc garmin mount from their website. Don't know if they are still around or not. It was a pretty small start up company. I have the original which was meant for the garmin 500 specifically. It's nice and tight to the bar, while their new version is 510 and 800 compatible. So if you have a 500, it sticks out a bit farther.
