My bikes - Evo + Tarmac+ Slice RS *Updates page 6*
Love it - so close to 5kg now! I'm putting some Sprinters (tan side walls) on mine. Definitely eager to see how they roll compared to the Contis that were on my rims. Let us know how they ride.
The veloflex ride beautifully. I wasn't a big fan of the vittoria corsa's that were on before but i can now see the rationale for tubulars over clinchers ither than weight saving. And there were super easy to glue yoo.
Loving the attention to detail on the evo build. I've got a few ideas from your build for my madone restoration build.
Few changes.
Got a bike fit, apparently not as flexible as I used to be, had to gain some stack, luckily already had my lighter 2016 evo fork on the way. So new fork was 261g after sanding and re clear coating. Have since cut off about 6-7 grams of length. (255g) - 40 or so grams.
Switched out my old ultrastar 2 (7g) for the new ultrastar 3 (6g) -1g
Switched out my wifli inner plate for fibrelyte 6g (-3g) - might still dremel this to be lighter still
Exchanged lower pulley for 11T extralite from 10T - same weight by my scale.
Spacers - had to switch from veloflyte top cap + microspacers + single 10mm spacer (6g) to had 15mm of spacers would have added 4g - 10g total but didn't like the look, so got out my tapered carbon spacer (17g) that came with the evo + alloy headset cover (5g) - dremeled the inner radius of the conical spacer to just three spars (post dremel weight 10g), had to dremel alloy spacer to work with FSA SL headset - took off 1g in the process and headset much smoother than before. Total spacer weight for 25mm - 14g. (+8g)
Have moved and don't have my scales but with the ax lightness wheels i must be sub 5kg well and truly. Will post some up to date photos with a scale shot but for now here are some updated photos with the meilensteins.
Frame 733 (bare)*
Fork 2016 255* (cut)
Headset FSA SL 33 g
Spacers - tuned stock evo alloy (4)+ tuned 25mm carbon conical (25mm) 14g*
Expander - extralite ultrastar 3 6g*
Top cap + bolt - extralite 2.9g*
Stem MCFK 120mm 96g*
Bar Haero 145 42cm - 155g*
Levers SRAM Red 22 (tune carbon clamps with Ti bolts + drillium) 262
Front Derailleur Sram Force w carbonice catcher + alloy limit screws + ti pinch and mounting bolt (forgot to weigh - 90ish)
Rear Derailleur - Sram Red 22 wifli, sanded, blacked out with nylon limit screws, alloy B limit, + extralite pulleys, carbon-ti pulley bolts, fibrelyte inner cage 149g*
Brakes eebrake 202* with campy carbon pads
Seatpost Carbonice 250mm 85g*
Saddle Berk lupina 132mm, 7mm rails, 1K cloth 66g*
Cassette Sram XG 1190 11-30 w extralite lockring 179*
Chain KMC SL Ti nitride 235*
Crank exogram DS 130bcd, 172.5mm, stages spindle, stages carbon NDS, Q rings OCP3, KCNC SL bolts, custom spacer - 560g* all in
Bottom bracket - central sleeve cut out 69*
Wheelsets
Meilenstein F 536 R693 =1229g* (replacement rear added 24mm after 2xspokes got eaten by a RD)
Tyres/Tubes GP 4000S (207* each) 414* (Clincher setup)
Continental supersonic 109g (Clincher setup)
Skewers Streeters, painted 29*
Ax lightness Ultra 25T 799g
Veloflex criterium 23mm x 2 513g*
Mastik
Skewers tune skyline 18g*
Sundry
Outers: RD iLink, FD iLink , Rear brake: front run - powercordz swift housing, rear run - powercordz swift, Front brake: powercordz swift
Cables: KCNC Ti brake, alero gold nano coated steel shift
bartape lizard skin DSP 1.8g (41*)
bar plugs carbon generic(4)*
derailleur hanger (10*)
cable guide (4*)
seatpost clamp smud (6*)
bottle cages with bolts carbonworks 12g*
Pro Chainstay protector 3.5g*
Garmin/light mount - home made carbon outfront stem bolt 33g* inc bolts. (2 grams saved as replaces 2x MCFK stem bolts.)
Look Keo Blade Ti 188*
Headset FSA SL 33 g
Wheelsets
Mastik
Sundry
cable guide (4*)
Always in awe when I see pictures of your bike. One of the best I've ever seen. And congrats on smashing 5kg!
Love the bike and the attention to detail. Awesome work.
I had a question on your Extralite QR skewers. How do you find the Streeters for ease of clamping / clamping force in comparison to other lightweight skewers you’ve used? Reason I ask is that to get sufficient force to prevent creaking under load with my meilensteins and the U20 skewers is not very easy. I have some Tune AC14 internal cam skewers which are much better in that regard, but obviously the streeters are quite a bit lighter.
Cheers, Dave
Cheers, Dave
The streeters have much better clamping force. See the fairwheel skewer shootout. That said I have just cracked one of the endcaps on the lever side. I would put some antiseize on the axles of the meilensteins - only thing that stocked my extralite hubs creaking (evo dropouts not square)
News.
Berk wasn't flat enough side to side for me, so have gone back to s works toupe + 29g compared to padded berk lupina
This required a setback post so back to ritchey superlogic 1 bolt + 50 grams vs carbonice
So currently 5.04kg.
BUT
Have switched from lizardskin DSP to deda traforato (?-10g)
Have switched from ilink to minilink for shifting with a more compact run (- 10-20grams?)
Have ordered a darimo setback in 250mm which should be around 85g (-50grams)
Have been testing an ax lightness leaf leather which seems to be working for me. (88g) - 25g
Have bought a cheap lightly used xg1190 11-28 (158 with extralite lockring) - (21g) vs 11-30.
So should be comfortably sub 5kg after part exchanges with the 11-28. Will update with pics when parts arrive.
News.
BUT
UPDATED FINAL LIGHT BUILD 4.90kg w 11-28 and ax lightness tubs, 5.44kg w 11-30 and lightweight meilenstein clinchers - likely to recover saddle using lighter leather to take off 10g eventually.
Frame 733 (bare)*
Headset FSA SL 33 g
Bar THM Ulna 42cm - 148g replaces (Haero 145 42cm - 155g*)
Rear Derailleur - Sram Red 22 wifli, sanded, blacked out with nylon limit screws, alloy B limit, + extralite pulleys (spacer made with aican bunagrus housing), carbon-ti pulley bolts, fibrelyte inner cage 149g*
Seatpost Darimo S2 3K 27.2 250mm ti nut replaced with alloy, standard bolt reaplced with same in gold ti (86g) replaces (Carbonice 250mm 85g*)
Saddle Ax lightness leaf - as stock 77g, custom covered with foam +4g, and kangaroo leather cover - final weight 99g replaces (Berk lupina 132mm, 7mm rails, 1K cloth 66g*)
Cassette Sram XG 1190 11-28 w extralite lockring 158g (XG 1190 11-30 w extralite lockring 179*)
Chain PYC 230g uncut replaces (KMC SL Ti nitride 235*)
Wheelsets
Mastik
Skewers Extralite streeters - custom painted 29g ( tune skyline 18g*)
Sundry
Outers Shift: Minilink , Brake:Powercordz Swift
Cables: KCNC Ti brake, Shift: alero gold nano coated steel shift
bartape deda traforato 30g replaces (lizard skin DSP 1.8g (41*))
cable guide (4*)
Frame 733 (bare)*
Headset FSA SL 33 g
Wheelsets
Mastik
Sundry
cable guide (4*)
I love this bike and I know you've done a heap of work to shave even a few grams off it, but......etap please
i know it would add a bit of weight, but you could possibly bring the derailleur cage over to offset some of that. just from as aesthetic point of view, i love how etap clears up shifting cables and give the bike a cleaner look
Your Evo is something special! Kudos on a great build!
Cannondale Systemsix Ultegra 2020
viewtopic.php?f=10&t=160844
Super climbing bike!NiFTY wrote: ↑Sun Oct 28, 2018 6:17 amUPDATED FINAL LIGHT BUILD 4.90kg - likely to recover saddle using lighter leather to take off 10g eventually.
Will switch between cassettes and chains.
Frame 733 (bare)*
Headset FSA SL 33 g
Wheelsets
Mastik
Sundry
cable guide (4*)
loving the details, why using Force FD?
5,4kg supersix black inc 2013 https://weightweenies.starbike.com/foru ... 8#p1454848
The force fd shifts q rings way better than the yaw fd. And compared to lighter dura ace fds it doesn't need any trim to have it rubless.
