My bikes - Evo + Tarmac+ Slice RS *Updates page 6*
Evo build updates ******http://imgur.com/a/xXj8a******* 5.13kg
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
Frame 733 (bare)*
Fork 303(with crown race)* 296* (cut)
Headset (- crown race) <51* ( fairwheel spacer, veloflyte, "sharkfin" + extralite hypercap, extralite ultrastar 2 expander, FSA SL upper bearing, standard evo lower)
Stem MCFK 120mm 96g*
Bar Haero 145 42cm - 155g*
Levers SRAM Red 22 (tune carbon clamps with Ti bolts + drillium) 262
Front Derailleur Sram Force w carbonice catcher + alloy limit screws + ti pinch and mounting (forgot to weigh - 90ish)
Rear Derailleur - Sram Red 22 wifli, sanded, blacked out with nylon limit screws, alloy B limit, + extralite pulleys, carbon-ti pulley bolts 152g
Brakes eebrake 202* with campy carbon pads
Seatpost Carbonice 250mm 85g*
Saddle Berk lupina 132mm, 7mm rails, leather + 3mm padding 84g
Cassette Sram XG 1190 11-30 w extralite lockring 179*
Chain KMC SL Ti nitride 235*
Crank exogram DS 130bcd, 172.5mm, stages spindle, stages carbon NDS, Q rings OCP3, KCNC SL bolts, custom spacer - 560g all in
Bottom bracket 77
Wheelsets
Meilenstein F 536 R669 =1205g*
Tyres/Tubes GP 4000S (207* each) 414* (Clincher setup)
Continental supersonic 109g (Clincher setup)
Skewers Streeters 29*
Ax lightness Ultra 25T 799g
Vittoria corsa G+25mm x2 567g
Mastik
Skewers tune skyline 18g*
Sundry
Outers: RD iLink, FD iLink , Rear brake: front run - powercordz swift housing, rear run - AICAN bungarus, Front brake: AICAN bungarus
Cables: KCNC Ti brake, gold nano coated steel shift
bartape lizard skin DSP 1.8g (41*)
bar plugs carbon generic(4)*
derailleur hanger (10*)
cable guide (4*)
seatpost clamp smud (6*)
bottle cages with bolts carbonworks 12g+
Pro Chainstay protector 3.5g*
Garmin/light mount - home made carbon outfront stem bolt 27g inc bolts.
Look Keo Blade Ti 188*
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
Frame 733 (bare)*
Bottom bracket 77
Wheelsets
Mastik
Sundry
cable guide (4*)
Link to the upper bearing please? I'm looking at the Ultratop and headtube is within tolerance, but €99 is a bit steep when all I need is the bearing cartridge.
Its on the fairwheel site.
Tarmac updates ******http://imgur.com/a/XX4w1***** 6.77kg
[url][/url]
[url][/url]
[url][/url]
[url][/url]
Frame S works SL3
Fork SL3
Headset Specialized
Stem 3T ARX Pro 110mm with ti bolts
Bar 3T Ergonova Team
Levers SRAM Red 2013 10 speed
Skewers KCNC Ti
Rear Derailleur - Sram Red 2013
Brakes Sram Red 2013 with campy for shimano carbon pads
Seatpost 3T doric, sanded
Cassette Sram Red black xg1090 11-28 + extralite lockring
Chain KMC 10SL
Crank Hollowgram SISL, SI stages NDS, aero spider, blacked out 53/39 Q rings
Bottom bracket specialized OSBB
Tyres/Tubes GP 4000S II 25mm
Sundry
cables: alligator i link + AICAN DLC.
bartape Fabric silicon
bar plugs Carbon generic
seatpost clamp carbon-ti
bottle cages with bolts Tune wassertrager uni
Wheelset
Xentis Squad 4.2 Clinchers (1450g w/o rimtape)
Look Keo Blade Cromo
Fetha outfront garmin/light mount
[url][/url]
[url][/url]
[url][/url]
[url][/url]
Frame S works SL3
Fork SL3
Headset Specialized
Skewers KCNC Ti
Chain KMC 10SL
Sundry
Wheelset
NiFTY wrote:Its on the fairwheel site.
Thanks. Did you only go for the upper? I'm away from home today, theyre 45° x 45° right?
Yeah only the upper fits. Pretty sure they are but check dimensions before ordering.
Cannondale Slice RS *****http://imgur.com/a/5ErZV ******* 8.89kg
[url][/url]
[url][/url]
Stem extenders drilled to take di2 cables - all junctions for front of bike within stem
[url][/url]
Kept having bottle fall out over bumps - 2x garmin rubber bands knotted together holds bottle in.
[url][/url]
Table tennis raquet grip glued to saddle with contact glue - grippy but not abrasive
[url][/url]
Black bullet under stem is aero cover for junction A - made from cover for weird brush golf tee I found, cut in half and painted black, window for button/lights underneath.
[url][/url]
Custom carbon plate garmin/light mount - made from 3mm carbon plate, pro missile mounting hardware and k-edge inserts. Also usefully stiffens the front end
[url][/url]
Used noodles rather than housing for brake run, able to run much tighter bends without friction
[url][/url]
[url][/url]
Frame Slice RS
Fork Slice RS
Headset Slice RS
Stem Slice RS - drilled, multiple extensions (beyond recommendations), extralong steel bolts
Bar Pro missile Evo, ski bends
Levers Dura-ace Di2 9070 brake/shifters, Ultegra di2 extension shifters
Skewers KCNC grooving
Front Derailleur Ultegra 6870
Rear Derailleur - Ultegra 6870/ fibrelyte/ red pulley bolts
Brakes Slice RS, reynolds cryo
Seatpost Slice RS, cut
Saddle Sitero expert, table tennis grip glued with contact cement
Cassette Ultegra 6800 11-25, token lockring
Chain KMC SL
Crank hollowgram SISL, aero spider w q rings 56/39
Bottom bracket Cannondale PF30
Tyres/Tubes GP 4000S 23mm (207* each) 414*
Continental supersonic + reynolds extender = 109*
Wheelset Reynolds Aero 90
Look Keo Blade 2 Cromo
Sundry
cables/housing - ilink, di2
Tape lizard skin DSP
bottle cages arundel chrono
Garmin/light mount/extension stiffener - homemade - 3mm carbon plate, pro missile hardware and boltsd, k edge garmin inserts, 2.5mm nuts and bolts.
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
[url][/url]
Frame Slice RS
Fork Slice RS
Headset Slice RS
Chain KMC SL
Sundry
Clincher setup 5.51kg. - meilensteins
What's the stiffness and braking like on the Ultra25Ts?
The Dale road bike is fab. Love the attention to detail. The work you've done on the cranks is a thing of beauty. It looks so much better than the graphic't standard cranks. Same with the rear mech. And extra kudos for doing the sanding etc yourself. One of the nicest bikes I've seen on here for a long time. Chapeau.
Thanks KB.
dereksmalls the stiffness and braking on the ultras is phenomenal. I am 72kg and I cannot get them to rub even up really steep pinches out of the saddle. The braking is on par with the xentis. I run campag carbon pads on both, no squealing, brake modulation and power in the dry, but not amazing in the wet (like all carbon i have tried). They brake better than my meilensteins and roval clx40s. Build quality is excellent too.
How much weight is saved with the new 11t Extralite lockring over SRAM? Thx!
http://webshop.extralite.com/add-to-cart/319
The Extralite 11t lockring for Sram is 4g
The current 11 speed one is 4g the prev 10 speed is 3g (which still works with 11) stock sram red lockring is 6g.
Updates.
PF30 bearing exchange after dremeling out center sleeve - saving 15g
Swapped in FSA SL bottom bearing (managed to get it to work) saved 9g
Swapped Vittoria corsa 25mm for veloflex criterium - much nicer tyres, mounted much nicer on the rims (shape matched better) saved 40g
Swapped from padded to unpadded berk saddle saved 18g
Beefed up garmin/exposure mount - now very stiff, even over bumpy roads (definately overbuilt now) +4g
Switched back to extralite streeters - better clamping force over the tune skyline ZFS +12g
Now 5.02kg with extralite skewers.
5.01kg with tune ZFS skewers.
Plans for the future fibrelyte inner plate for tuning. Berk combo.
