lightest centre lock rotors?
ianthom
by ianthom
Hey guys, what are the lightweight centre lock rotor options?
Jaker
by Jaker
A tuned DT centerlock adapter (11g), 12t aluminum cassette lockring (6g), and a 6 bolt Scrub Components rotor (56g) = 73g. You're ahead on the bolts too, as you don't need them with this adapter, so 6g minimum saved there.
Gran Sport
by Gran Sport
Jaker wrote:A tuned DT centerlock adapter (11g), 12t aluminum cassette lockring (6g), and a 6 bolt Scrub Components rotor (56g) = 73g. You're ahead on the bolts too, as you don't need them with this adapter, so 6g minimum saved there.
or even lighter! my rear brake set-up is 69g with a 160mm rotor +7g upfront with 180mm rotor.
Scrub have even lighter rotors on the way soon, seen pics of a prototype 46g 160mm rotor with a magnesium spider
DHracer
by DHracer
yup the proto is 46g but the final version is gonna weight 36g's in the 160mm version :wink:
Gran Sport
by Gran Sport
36g for 160mm rotors would be phenominal!
ianthom, sorry back to topic
both Hope & Formula manufacture lightweight centrelock rotors, but best to check with their websites for the size you need to get weights
Shimano owns the centrelock patent, the current XTR RT97 centrelock rotors are abit hefty compared to what's available from Hope or Formula @ approx 162g for 180mm, 140g for 160mm & 111g for 140mm (rear only)
hope that's of help
dansills2000
by dansills2000
Quick question - where are you guys getting the "tuned" dtswiss adapters that weigh 11 grams?
