rear Quickrelease Epic S-works
biky
by biky
Does anyone know which QR is long enough is for the rear wheel of an
S-works 2009
I have an carbon controletech that is to short and for as far as I know the only option is a Roval and they are not the nicesed (ugly)
Tarmac SL2
Epic 2009
Tiffster
by Tiffster
controltech make carbon QR ??
jmartpr
by jmartpr
If you mean the wheel quick release...KCNC is now making in limited runs a skewer set with a 230 mm rear one. We worked with them on this design for the Trek EX FS with ABP that also use a longer rear skewer.
If your requirements fall between a regular one and this one you could always tap some treads and cut the excess...this is what we did with a Top Fuel 9.9 as they too use a rear skewer in between the Trek EXs and the normal MTB rear skewer.
ryan_sherlock
by ryan_sherlock
KCNC also have a 5mm longer one coming out around now. clee cycles are sending us replacements as our originals were just a bit too short.
Currently, until I get them I'm running the standard roval ones.
jmartpr
by jmartpr
ryan_sherlock wrote:KCNC also have a 5mm longer one coming out around now. clee cycles are sending us replacements as our originals were just a bit too short.
It's a bit longer than 5 mm...we already have the first sets here. The ended up too long for the Trek EXs but that can be easily fix.
xptxc
by xptxc
I use a BBB http://www.bbbparts.com/quickreleases_f ... -bqr04.php thats works fine - its also light and strong being a cromoly skewer.
I cans also measure my Ti tune to see, biut I assume they work has they did on my previous epic
biky
by biky
BBB is for me not an option (don´t like the brand name)
I reseved an E-mail from carbon-TI that the have a special X lock special in XL specialy made for these type of frames
Tarmac SL2
Epic 2009
Sonny
by Sonny
jmartpr wrote:If you mean the wheel quick release...KCNC is now making in limited runs a skewer set with a 230 mm rear one. We worked with them on this design for the Trek EX FS with ABP that also use a longer rear skewer.
Just need to swap the axle and little modification works.....
dreadlaw
by dreadlaw
Sonny, show us your new bike please.......
jmartpr
by jmartpr
But if you use the stock Bontrager axle you end up with the heavy axle since it's not the KCNC Ti....
Sonny
by Sonny
The axel of QR come with my frame (top fuel 9.9 SSL)is titanium already. :D
biky
by biky
are the X/lock specials improved, because I read al couple of bad things about them
Tarmac SL2
Epic 2009
Belabianchi
by Belabianchi
Carbon-ti have Xlock special 2009 for new 2009 epic s-works
njee20
by njee20
I just run standard Tune skewers in my 09 Epic, no problem at all.
A road length skewer probably won't work, but can't see the issue with any normal skewers.
Tiffster
by Tiffster
Sonny
Do you like the Scrub rotors ? My finger is itching to place an order for a pair....
