Crank thread problem
nikosthom
by nikosthom
Hellow while i was trying to remove a square taper crank with the extractor the thread of crank failed.Maybee the crank was overtight or bad quality(cheap shimano altus).Is there any solution or i should cut the crank with cutting wheel?I m sure that the exteactor was in the right place.
Στάλθηκε από το SM-A127F μου χρησιμοποιώντας Tapatalk
joejack951
by joejack951
Do you plan to reuse the crank? If so, get a cheap automotive gear puller and it will make quick work on removing the arm.
Otherwise, go for a ride with the crank bolt installed but loose and let the crank arm loosen up on its own. Or cut it.
