the best mtb: 16.39lbs/7.4kg with pm
specs:
Frame: s-works epic ht chinese carbon clone 850g and 550 usd
Cockpit: kalloy uno and mt zoom setup for 203g and 130 usd
Seatpost: elita one seatpost with carbon/ti/aluminum hardware for 120g and 28 usd
Saddle: full carbon saddle 75g and 20 usd
Wheels: dt240s, spim cx ray spokes and creative carbon rims for 1155g and 1900 usd
Cassette: sram xo1 11 speed for 268 grams and 380 usd
Shifter: sram x01 11 speed for 91 grams and 91 usd
Derrailler: xx1 11 speed for 241 grams and 240 usd
Cranks: cannondale hollowgram si with stages pm for 455g and 600 usd
Chainring: absolute black oval for 61g and 75 usd
Grips: Hypergrips for 7 grams and 20 usd
Fork: sid sl ultimate for 1326g and 700 usd
Headset: fsa 80g and 50 usd
Brakes: level utimates for 636g and 570 usd
Rotors: ashima ai2s 120g for both and 30 usd
Chain: ybn sla chain for 269 grams and 56 usd
Tires: maxxis aspen for 1268g and 150 usd
Rear axle: one thats included in the frame for 36g and 0 usd
Bottom bracket: hambini one that fits the frame 84g 277 usd
Totals
Weight: 7435 grams or 16.39 lbs
Price: 5517 usd
overall its light as *f##k* and cheap as *f##k* in comparison to other bikes that are of similar caliber and all the parts are reliable this build will also look slick as *f##k* if you get it all built and painted in black and strip the fork (-40ish grams!) to a chrome silver and make sure everything else is blacked out
Totals
Price: 5517 usd
I looked at doing a HT build like this... started w the same frame. It's a great idea if you live in the right place, for some this is closer to a gravel bike. you might be a few parts missing here like tubeless setup and rotor bolts maybe 200g there.
- robbosmans
- Moderator
- Contact:
Euhm, what is this thread supposed to be?
You forgot: cables, sealant, pedals etc
This is all just hypothetical and not real.
Also u watch to much Hambini
Heh - miss me with those grips (ESI's are just fine) and the saddle (unless you plan on using this HT as a gravel bike). Also, while super light, you have a potentially questionable frame on a 5500 bike just to save 2 lbs - buy an epic HT frame used.
The saddle is super comfy with a decent chamois and shape>paddingComeKnowMeAsGC wrote: ↑Tue Aug 23, 2022 8:18 pmHeh - miss me with those grips (ESI's are just fine) and the saddle (unless you plan on using this HT as a gravel bike). Also, while super light, you have a potentially questionable frame on a 5500 bike just to save 2 lbs - buy an epic HT frame used.
Yeah I use esi racers edge but then grips light as *f##k* and look sick
The frame is sick as *f##k* and built well (I use it on the daily)
Cables included in brakes/shifterrobbosmans wrote: ↑Tue Aug 23, 2022 3:40 pmEuhm, what is this thread supposed to be?
I don't do the pedals cause personal preference
Sealent is pretty shmol but ight
Hambini makes super solid bbs that remedy poorly built bbs and spin le good
Pedals are down to preference too much
I have SHLAMMED this bike down trails (big kommer right here) and it's ight
Rotor volts is like a couple g's
