2022 N+1 light trail bike beater options
I built it frame up.prokyon wrote: ↑Fri Nov 11, 2022 1:10 amWhat build level do you have? Pro? Expert? Comp?OnTheRivet wrote: ↑Tue Nov 08, 2022 8:34 pmMy 2022 S3 stumpjumper is 25.7lbs with 870g tires a pike and a quarq power meter. I built it for technical trail riding but want to throw some lighter tires on it and do some XC racing.
XX1 crank
Light bicycle wheels (240 hubs) 1390g on my scale
One up dropper post
XX1 mech shifter/derailleur
E13 cassette
Sram guide rsc brakes
Syncros carbon railed saddle
Trail one carbon bar cut to 760mm
Crank bros ti candy pedals
Race face r35 stem
Ti bolts everywhere.
Specialized Ground control tires..
https://www.santacruzbicycles.com/en-US/bikes/blur
Blur
$5549 11.88kg / 26.18lbs
$6599 11.65kg / 25.69lbs
$7849USD 10.65kg / 23.49lbs
$9799USD 10.39kg / 22.91lbs
$12099USD 10.23kg / 22.56lbs
for an N+1 beater bike like in the description I am going to assume the guy is going to want the cheaper bike so closer to 25lbs after he does some mods.
Blur
My 2023 Lux CFR is 10.12 kg 22.31 lbs with Vecnum XC dropper + XPedo X-Force 8Ti pedals + bottle cage. Almost stock, however changed the bulky 2.4 Maxxis tires to 2.25 Schwalbes (-150g), however added my old Quarq power meter (+119g). Okay, SID SL is not a trail fork but Canyon factory racers sometimes also use Fox34 with this new Lux CFR frame, so this one could be a good trail bike around 23 lbs with a SID 35mm or Fox 34. (Geometry is almost the same like the Blur)
It's very cabable even with 2.25 tires and SID SL 100mm though, tested on a few local demanding trails.
