Lefty XLR 2015 Rebound Adjust
tarmackev
by tarmackev
I've just purchased an immaculate 2015 FSI
The fork holds air just fine but the rebound is quite slow.
I've tried to turn the adjust (Rockshox remote) on the top of the fork but it only moves 10mm or so in each direction, do I just need to give it beans and push it further?
Should the rebound rotate more than this?
The bike has been sat in a dry bedroom for a couple of years.
I added some lube this morning and will go back to it tonight.
Any help is much appreciated.
js
by js
Likely best to send it away for service - possible the oil levels or low, but whatever the cause, if you let a service shop know you're looking for faster rebound, they'll be able to tune it to your desired spec.
