SRAM AXS service
la85
by la85
Hey all,
Is there such thing as a service on AXS rear? I've had a good look online and can't find a thing.
Does anyone have any info on what you could go to freshen it up?
My eagle xx1 axs rear is a couple of years old and has coped some kms so would like to freshen it up.
Apart from jockey wheels and a kit with new screws etc is there anything that can be done?
Cheers
Locky
thewoodsman
by thewoodsman
if you search for "(your der. year) sram spare parts catalogs" you might be able to find the pdfs of all the replaceable parts. not sure how many years they maintain. for my eagle axs der. (2021), you can only replace the inner cage, pulleys and bolts, B bolt kit, limit screws, and clutch cover. i always replace the pulleys with aluminum because i hate the stock material; otherwise none of these parts should wear so soon. Maybe try pulling those out and regreasing, check your hanger alignment, and adjust your limit screws.
req110
by req110
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
