Two bottle cages on a single cage frame
samarskyrider
by samarskyrider
Hello everyone,
I have a BMC Fourstroke frame and look for a solution to mount 2 bottle cages inside the frame. Can anyone share their experience on solving this problem?
I've seen 2 bottles mounted side by side, but I don't think it's a good idea
Below is the picture of actual frame
req110
by req110
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
samarskyrider
by samarskyrider
Thank you!
I've found them yesterday. I was wondering maybe something else exists
1llum4
by 1llum4
Maybe this from wolftooth could work ?
Wolftooth B-Rad Double Bottle Cage
samarskyrider
by samarskyrider
1llum4 wrote:Maybe this from wolftooth could work ?
Thanks for the link, but from what I see - it won't be convenient when pedaling out of saddle
1llum4
by 1llum4
Then maybe this under the top tube ?
Wolftooth B-Rad Everywhere base
jemima
by jemima
I've tried a couple of those thin velco strap offerings. No where near the holding/clamp strength of the TwoFish Quick Cage Adaptor; 3bolt version.
(The 2bolt version works ok, but with a full bottle it does swing around a touch, across rough ground).
May have room higher up on the downtube with a sideloading cage, if you used the lowest bolt+cage position for the lower bottle.
Otherwise below the toptube (towards the front end); again with sideloading cage.
Arundel sideloading cage works very well with the 3bolt.
Curve Grovel ti.
froze
by froze
Won't a side by side set of bottles interfere with your legs while pedaling? Or, what if you go down will a bottle, and or the cage itself, jack up a leg?
jemima
by jemima
froze wrote:
Sat Jan 22, 2022 10:53 pm
Sometimes I'll run the cheap M-Wave mount on the downtube holes, with two opposing sideloading cages.
Legs never hit when pedaling.
Less injury chance going down -in my mind- when both cages are holding a bottle.
With bottle in, that offset position also makes for a nice spot to rest the frame against when shouldering the bike.
Curve Grovel ti.
MikeD
by MikeD
I went with a massive 38 oz Soma Further water bottle. I couldn't find any other solution that worked for me.
warthog101
by warthog101
I like it. Great solution Image
IchDien
by IchDien
Could you not put one on the saddle?
samarskyrider
by samarskyrider
IchDien wrote:Could you not put one on the saddle?
It's not convenient on XC bike, especially when you need lean over the saddle
thewoodsman
by thewoodsman
You could try the Wolftooth B Rad mounting bases if two bottles could stack on top of the downtube:
https://www.wolftoothcomponents.com/col ... ory-device
In addition to this rail, I have used the B Rad everywhere base on both sides of the top tube and bottom of the downtube. I know you said you don't like the Wolftooth double, but I use it on both my hardtail and gravel bike without issue.
samarskyrider
by samarskyrider
Thank you everyone,
I've asked my local CNC man to draw and machine this piece
