Hardtail MTB Frame that can accept a 40t chainring?
Hi Everyone,
Does anyone know of a hardtail mtb frame than can accept a 40t chainring? My goal is to build up a "frankenbike" that can double as both a hardtail mtb and on the occasion be used for chunky gravel races as a drop bar hardtail using the new Surly Corner Bar to make the switch.
The frame doesn't have to officially accept a 40t, I'd just want to make sure it would clear the chainstay.
Thanks in advance!
Thanks in advance!
- robbosmans
- Moderator
- Contact:
Garbaruk has size based offset, this way it will fit on a lot more frames.
Dangerholm for instance used it on a scott spark
Roger that and thanks for the input. I'm assuming I'd want a 0mm or 3mm offset (at most) for the chainring, no? This way the chainring would be farther from the chainstay.
In The Netherlands, we convert MTB's for riding on the beach. I'm currently using a Cube Reaction frame, and will fit a 44t chainring. What i've seen is that if u use an alloy frame you have more clearance (less offset) than carbon frames, due to bigger chainstays. Other people use Specialized Chisel, Giant XTC. Hope this helps.
Dutch
Orbea Orca OMX 2020
Startersbike: Cube Attain 2017 (mounted@ Tacx Neo2)
Orbea Orca OMX 2020
Or go for a 9t cassette, gives you 20% smaller ring compated to 11t and 10% smaller to 10t
Koev wrote: ↑Mon Sep 06, 2021 3:00 pmIn The Netherlands, we convert MTB's for riding on the beach. I'm currently using a Cube Reaction frame, and will fit a 44t chainring. What i've seen is that if u use an alloy frame you have more clearance (less offset) than carbon frames, due to bigger chainstays. Other people use Specialized Chisel, Giant XTC. Hope this helps.
Good point and thanks for the input!
